3 dyno 3 different shop NO GAIN
DAC
DC 4-1
Apexi N1
HKS camgear (untune)
8mm wires
Last run with silencer off
DAC
DC 4-1
Apexi N1
PFR
HKS camgear (dyno tune)(+2I -2E)
8mm wires
Ran all dyno with silencer on
DAC
JDM DC 4-1
Hybrid garage carsound cat
Apexi N1
HKS camgear (untouch since last dyno tune)
8mm wires
100 octane gas
Very dissappointed result.
DC 4-1
Apexi N1
8mm wires
DAC
DC 4-1
Apexi N1
PFR
8mm wires
DAC
JDM DC 4-1
Apexi N1
8mm wires
100 octane gas
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR 599 »</TD></TR><TR><TD CLASS="quote">the numbers you put down sounds about right for the mods you have. </TD></TR></TABLE>
yea... those numbers sound about right with those mods...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Integra »</TD></TR><TR><TD CLASS="quote">100 octane? there's your problem right there
DC 4-1? another problem</TD></TR></TABLE>
The JDM DC 4-1 is a fine header. Have you seen the Great Header Test?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00 FBP ItR »</TD></TR><TR><TD CLASS="quote">they only adjusted your camgears once? thats no dyno tune..
where do you want the power to be? midrange or topend?</TD></TR></TABLE>
Camgear was adjust 5 different time on the 2nd dyno. I one I post was the final and best result. I will try some other # on the next dyno.
Your exhaust is a little small, the N1 is only 60mm while your header is 65mm so you're getting some power cut off there. What series Carsound cat are you using? If the first digit is under 9 and the last digit is under 6, you may be getting choked there too.
I was making about 170whp with a similar setup untuned so you're about right give or take. Probably try using regular 91-93 octane, you may get better results. Using higher octane doesn't give you any power unless you raise your cylinder pressures and tune for it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface »</TD></TR><TR><TD CLASS="quote">
The JDM DC 4-1 is a fine header. Have you seen the Great Header Test?</TD></TR></TABLE>
peak HP...i cant argue.
but compared to some of the other headers out there...it was not a good selection for mid range hp imo.
my god, look at that a/f curve. you would benefit from fuel tuning.
100 octane wont burn that well unless you advanced the timing a lot or are running real high compression which you are not.
those numbers are, ok, but not that good. Normal? dunno. my gsr put down 169/122 with I/H/E/VAFC/Cat and 18 deg. timing..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soup **** »</TD></TR><TR><TD CLASS="quote">peak HP...i cant argue.
but compared to some of the other headers out there...it was not a good selection for mid range hp imo.</TD></TR></TABLE>
Only .5hp difference between it and the best.
5.5K-8.4K
spoon 168.3266667
toda 168.14
SMSP 168.1
type one 168.0433333
dc jdm 167.81
ITR JDM 167.3833333
comptech 167.3233333
Mutech 166.8666667
Mugen 166.38
Jun 166.1033333
stock 2.5 161.6866667
stock 159.7366667
5.5K-8.4K
spoon 168.3266667
toda 168.14
SMSP 168.1
dc jdm 167.81
ITR JDM 167.3833333
Mutech 166.8666667
Mugen 166.38
Jun 166.1033333
stock 159.7366667
great header test was just bolt on.
after tuning, some people got like +11hp midrage with an
IB modded jg/edlebrock header over the jdm/dc 4-1..and more top end too.
same thing with the header tech header.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVOL »</TD></TR><TR><TD CLASS="quote">after tuning, some people got like +11hp midrage with an
IB modded jg/edlebrock header over the jdm/dc 4-1..</TD></TR></TABLE>
You mean a 11hp spike in the midrange, or the average between x,000-x,000 rpm was 11hp more?
Don't worry about this joker. He talks before he thinks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">You should try a different tuner, maybe...</TD></TR></TABLE>
A different tuner wont matter so much. I'm guessing he wants peak power (money shot ownz all y0! lol ) and he needs something to control fuel to lean out the top end since it's running rich as hell.
All he has currently are cam gears.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mario »</TD></TR><TR><TD CLASS="quote">
Wow mario, that was a very helpful post by you. I wonder if your car is as quick as your mouth
Anyways, on 2 of his dynos he said dc 4-1. On the last one he said jdm dc 4-1. There's a big difference between the two. I assumed the dc 4-1 was being used.
However the charts look fine, but if he is using 100 octane gas it might be robbing him some power
</TD></TR></TABLE>Wow mario, that was a very helpful post by you. I wonder if your car is as quick as your mouth
That looks about normal to me. Some ITR motors make more power than others. Maybe you got a Friday motor?
Really though don't feel bad about your #'s and listen to the people above and try and do a few more things differently. All in all I hope you get the results you are looking for.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austin »</TD></TR><TR><TD CLASS="quote">The 100 octane is killing you, I lost ~5whp when testing 96 octane when I was tuned for 91 octane.</TD></TR></TABLE>
so what's stock ITR's ecu tuned? is it tuned for 91? so does that mean using 94 is no good?
yeah, and I ran slower times with 100 octane then when I was on 91...
