compression and bore...
Old Jul 3, 2003 | 08:34 PM
untitled's Avatar
Default compression and bore...
my ls block has 195k on it. i started to tear it down for the lsvtec build to day. i just read a post saying that you should sleeve a motor when running over 11.5:1 compression and that you should reslveeve it if you are going to bore over .5 mm. is this true? i was planning on running pr3 pistons. on the c-speed calc i come up with 11.6:1.id like your opinions on this block setup. the rods i am going to run are 45k ls rods with arp rod bolts.
Old Jul 3, 2003 | 09:08 PM
eg_type_r93's Avatar
too many clicks on that ls motor sleve it or get rid of it thats my opinion
Old Jul 3, 2003 | 09:16 PM
untitled's Avatar
Default Re: (eg_type_r93)
people have told me it doesnt matter. however i think it does but not alot. also this is goign to be a very mild setup.
Old Jul 3, 2003 | 09:21 PM
Ivan's Avatar
senior gold member
Default Re: (88crx91integra)
I would take it apart and have someone experienced have a look at the cylinder bores.
Old Jul 4, 2003 | 03:33 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: compression and bore... (88crx91integra)
Well if you are rebuilding it then it will be a new fresh motor. 82mm is the largest I'd go on stock sleeves for N/A. 11.5 is fine. Build on....
Pmhearns
Feb 4, 2015 08:59 AM
civic-r11
Jul 13, 2009 06:00 PM
maxpower98
May 1, 2009 08:26 AM
Aro321
Dec 22, 2006 11:43 PM
seanc520
Oct 17, 2006 06:08 PM
