Is the 2nd gen b16 the only motor that used the PR3 pistons?
Old Jul 3, 2003 | 06:29 PM
Poop111444's Avatar
Default Is the 2nd gen b16 the only motor that used the PR3 pistons?
OR did the 1st gen b16 also use the PR3 pistons. Im looking at buying a set of pistons for my 99 b16a2 from this guy, and the pistons are stamped PR3. He's unsure of the age/milage, but the condition is good. I'm just wondering if they came from a 1st gen, in which case i probably wouldn't want.
Thanks
Old Jul 3, 2003 | 06:39 PM
eg6h8k's Avatar
Default Re: Is the 2nd gen b16 the only motor that used the PR3 pistons? (si_mekanik)
PR3 are from 1st gen b16a and also from all usdm b16s..get the p30 they have alittle more compression..or CTR..
Old Jul 3, 2003 | 06:50 PM
DOHCtorTHRUST's Avatar
Default Re: Is the 2nd gen b16 the only motor that used the PR3 pistons? (eg6h8k)
dont bother buying another set of b16 pistons, you minus well get ITR's or CTr's you'll be happy with the power(i should say compression)...
Old Jul 3, 2003 | 07:40 PM
Poop111444's Avatar
Default Re: Is the 2nd gen b16 the only motor that used the PR3 pistons? (DOHCtorTHRUST)
Im running 9psi of boost
Old Jul 3, 2003 | 07:44 PM
allmtr's Avatar
actually... the jdm 2nd gen only used p30. u.s. and 1st gen used pr3
Old Jul 3, 2003 | 09:29 PM
built562's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si_mekanik &raquo;</TD></TR><TR><TD CLASS="quote">Im running 9psi of boost </TD></TR></TABLE>
then maybe you should run some ls pistons to lower the compression even further and want to stay on a budget
candy eg
Northern California (Sales)
Apr 24, 2006 12:31 PM
tissimo
Apr 30, 2005 11:36 AM
spidermancivic
Apr 12, 2005 11:26 PM
lemongreenhatch
Jun 2, 2004 04:54 PM
dohcMONSTER
Nov 25, 2003 04:38 PM
