Is the 2nd gen b16 the only motor that used the PR3 pistons?
OR did the 1st gen b16 also use the PR3 pistons. Im looking at buying a set of pistons for my 99 b16a2 from this guy, and the pistons are stamped PR3. He's unsure of the age/milage, but the condition is good. I'm just wondering if they came from a 1st gen, in which case i probably wouldn't want.
Thanks
Thanks
Re: Is the 2nd gen b16 the only motor that used the PR3 pistons? (si_mekanik)
PR3 are from 1st gen b16a and also from all usdm b16s..get the p30 they have alittle more compression..or CTR..
Re: Is the 2nd gen b16 the only motor that used the PR3 pistons? (eg6h8k)
dont bother buying another set of b16 pistons, you minus well get ITR's or CTr's you'll be happy with the power(i should say compression)...
actually... the jdm 2nd gen only used p30. u.s. and 1st gen used pr3
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si_mekanik »</TD></TR><TR><TD CLASS="quote">Im running 9psi of boost </TD></TR></TABLE>
then maybe you should run some ls pistons to lower the compression even further and want to stay on a budget
spidermancivic
04-12-2005 11:26 PM
lemongreenhatch
06-02-2004 04:54 PM
