can you anyone help me???
Old Jul 3, 2003 | 05:42 PM
DXturbo's Avatar
Default can you anyone help me???
does anyone know where this plug goes?
and... what bout the charcoal canister? theres a nipple that i didnt used..should i just plug it up?
THANKS
Old Jul 3, 2003 | 06:15 PM
pornstarSR's Avatar
Default Re: can you anyone help me??? (DXturbo)
the connector your holding up is either tps or Map...which both are on the throttle body, you can easily swap them so if you have any doubts , and if the car is running weird, try swapping. BUT BOTH should be connected in order for the car to drive..
as far as the nipple, it usually hooks up to hose that then gets hooked up to a nipple right on the very top of the throttle body, but it looks like you have something there already....try plugin it, Im not sure if there will be any effect since its a smog thing....i dont presonally have that on my version of the dx(no upper nipple) soo i cant say what happens for a fact....but it wouldnt hurt trying to plug it for now
Old Jul 3, 2003 | 06:40 PM
DXturbo's Avatar
Default Re: can you anyone help me??? (pornstarSR)
its not the map sensor or tps plug cause they are all plugged up. any other suggestions?
Old Jul 3, 2003 | 06:45 PM
DOHCtorTHRUST's Avatar
i beleive dx's have the map sensor on the firewall ( or some kind of sensor) that is suppose to ocuppy that plug that your holding, also that sensor is suppose to be hooked up to the canister
Old Jul 3, 2003 | 07:02 PM
pornstarSR's Avatar
hmm well on my dx its only has 2 plugs that look like that...
maybe its a evap purge solonoid......hmm now im gona rack my brain till i get to the shop tomarrow to figure it out
Old Jul 3, 2003 | 07:06 PM
pornstarSR's Avatar
well i know you probably want to figure it out soon so im gona make a suggestion.
its gona be a stupid one but it might help
look on the motor and see what sensor isnt plug in, that looks similar to that plug.
not trying to be a dick, just cant figure it out for sure till i get to the shop
Old Jul 5, 2003 | 01:56 PM
DXturbo's Avatar
i double checked everything on the motor and nothing is unplugged. the harness was on the firewall next to the battery. i have no idea where it goes. any onyone else?
Old Jul 5, 2003 | 02:27 PM
pornstarSR's Avatar
what about speed sensor on the tranny?
carlos8
Dec 31, 2013 03:14 AM
MJOLNIRvTEC
Aug 25, 2008 06:40 PM
VTEC Visions
Feb 24, 2005 02:25 PM
TurboBumblBee
Mar 7, 2002 07:49 PM
