Problems with the JRSC on my Type R
Old Jul 3, 2003 | 02:37 PM
ATgrills.com's Avatar
Default Problems with the JRSC on my Type R
Well we finally finished the install after 2 days of working on it....
I have a few problems...
1- the main blower pully only clears the master brake booster by 1/4 inch so if I downshift or go in reverse (it pushes the back of the motor up) and the pulley rubs against the brake booster... ***look at the pics for details***
2- If I plug the bypass valve vacum line to the throttle bodyI cannot get any boost whatsoever.. So then we pluged it into the fuel pressure regulator vacum line with a T... then I got spiking to 4.5psi but drops to 2-3 psi at arround 6k ........
3- I cannot get any boost over 4.5psi.........
please someone help me out.. and please dont say take it off, I had a turbo B18 civic last year and wanted something different with more reliability...
AND PLEASE DONT LAUGH AT THE FILTER ITS ONLY TEMPORY.." I HAD A AEM"
and my DC 4-1 header and full exhaust is going on tomo.......
thanks
Tyler
Old Jul 3, 2003 | 04:26 PM
Type-ARR's Avatar
Default Re: Problems with the JRSC on my Type R (ATgrills.com)
Should have went turbo....sorry I bet that didnt help at all.
Old Jul 3, 2003 | 04:41 PM
Default Re: Problems with the JRSC on my Type R (Type-ARR)
like I said, i was turbo last summer with my civic and wanted something more reliable.. 250WHP is fine by me!!!! no need for 300 on the street...
Old Jul 3, 2003 | 04:44 PM
cnydelSolHybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATgrills.com &raquo;</TD></TR><TR><TD CLASS="quote">like I said, i was turbo last summer with my civic and wanted something more reliable.. 250WHP is fine by me!!!! no need for 300 on the street...</TD></TR></TABLE>
Sure there is, turbo xs dual stage. 5psi for daily driving and then Flick it and GO
Old Jul 3, 2003 | 05:05 PM
uNF$@#!'s Avatar
Default Re: Problems with the JRSC on my Type R (cnydelSolHybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cnydelSolHybrid &raquo;</TD></TR><TR><TD CLASS="quote">
Sure there is, turbo xs dual stage. 5psi for daily driving and then Flick it and GO </TD></TR></TABLE>
yeah. uhm. flick it, and go boom.
Old Jul 3, 2003 | 05:12 PM
Dr Pooface's Avatar
IM Rboosted717, he's the local supercharged guru.
Old Jul 3, 2003 | 05:15 PM
Batoutahell's Avatar
Your blower pulley should fit perfectly between the brake mc and the brake line. When the blower and manifold are bolted up to the engine, there isn't any way to move the blower pulley left-to-right, so something else is wrong. Is your brake mc lined up properly on the booster? Are all of your motor mounts in good shape (not sagging or leaning)? When you get it lined up correctly, you'll have about a belt's thickness between the brake mc and the pulley.
Old Jul 3, 2003 | 05:26 PM
Default Re: Problems with the JRSC on my Type R (Batoutahell)
well looks at the pics, they dont lie.. my mounts are fine and the car has like 50miles on it....
ahhh why dosent it fit?
Old Jul 3, 2003 | 05:30 PM
sgT's Avatar
sgT
you want reliability yet you still use an FMU......
Old Jul 3, 2003 | 05:31 PM
01-0720's Avatar
Default Re: Problems with the JRSC on my Type R (sgT)
dude you need to clean your engine bay, thats disgusting
Old Jul 3, 2003 | 06:02 PM
Default Re: Problems with the JRSC on my Type R (01-0720)
my engine bay has nothing to do with the way my car runs....
and yes I will be chnaging to hondata 2b very soon but I need to work out these problems first!
Old Jul 3, 2003 | 06:55 PM
If you are confident that your engine is properly positioned in the engine bay, then my second recommendation is that you check the blower for damage. The blower pulley may be "jammed" into the nose cone, which would explain why it's hitting the mc. The shaft and bearings are not sturdy, and I have heard of the shaft getting pushed into the blower, once during a not-so-delicate installation and also during a pulley swap.
Old Jul 3, 2003 | 07:17 PM
JDMparts4u2
Guest
Posts: n/a
Simple Green is your friend
Old Jul 4, 2003 | 01:57 AM
egsick6's Avatar
Yea, your bay needs to be pressure cleaned for sure.
Old Jul 4, 2003 | 05:34 AM
Chubz's Avatar
Default Re: Problems with the JRSC on my Type R (damius)
dude clean the engine bay, thats nasty. Looks like a messy skidmark
Old Jul 4, 2003 | 05:48 AM
BudMan's Avatar
Default Re: Problems with the JRSC on my Type R (B18CR01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CR01 &raquo;</TD></TR><TR><TD CLASS="quote">dude clean the engine bay, thats nasty. Looks like a messy skidmark</TD></TR></TABLE>
lmao - that car has been in a flood...notice a bunch of bolts are rusty & there is dirt/mud stains where they shouldn't be. I hope the owner knew what he was getting into.
**Have you checked the serial numbers to see if the engine/body match? You may find a few of your current problems are residing in this process. GOOD LUCK.
Old Jul 4, 2003 | 05:52 AM
01-1293's Avatar
Default Re: Problems with the JRSC on my Type R (BudMan)
is it just me or does the engine look like it's sitting a little bit too far back? I remember my header heat shield being closer to the rad
Old Jul 4, 2003 | 08:17 AM
JDM CTR '00's Avatar
Default Re: Problems with the JRSC on my Type R (01-1293)
dude the guy asked for help on his SC not help on cleaning his engine bay. Have you called JR? If not Call them and let them know. Was this a New or Used unit?
Old Jul 4, 2003 | 09:56 AM
io_burn's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BudMan &raquo;</TD></TR><TR><TD CLASS="quote">
**Have you checked the serial numbers to see if the engine/body match? You may find a few of your current problems are residing in this process. GOOD LUCK. </TD></TR></TABLE>
Eew... you're right...
Old Jul 4, 2003 | 01:32 PM
Default Re: Problems with the JRSC on my Type R (io_burn)
flood.. LOL.. its called rust proofing.... i live in canada and the old owner use to drive it in the winter
im really getting sick of this supercharger...... im gonna pick up a CRV pulley on monday and if things dont get better... this things is going in the garbage!!!!
Tyler
Old Jul 5, 2003 | 07:47 AM
Do I dare ask how you expect swapping in a CRV pulley could possibly cure your problem?
Old Jul 5, 2003 | 08:55 AM
4doorB18Bcivic's Avatar
How bout some tuning......
Hondata May help you with that???
Old Jul 5, 2003 | 09:01 AM
HYREV2NR's Avatar
Thanks for the pics considering I'm looking into installing one on my R also. As far as the pulley scrubbing the mas. cyl., I would either install a smaller blower pulley or install solid motor mounts or inserts. I have Prothane inserts & the motor doesen't give @ all. But I'm not sure why its not lining up. Good luck!
Modified by HYREV2NR at 12:14 PM 7/5/2003
Old Jul 5, 2003 | 03:43 PM
ultimatehonda's Avatar
Has the car ever been in a accident??...frame damage???
Old Jul 5, 2003 | 06:47 PM
2camsaam's Avatar
certainly not one of the cleaner engine bays, especially for an ITR.
.02 Sorry
