GSR or Si sway bar
Old Jul 3, 2003 | 12:35 PM
99civic_exSB's Avatar
Default GSR or Si sway bar
On the 96-00 Civic EX do you need any sort of reinforcement to mount the GSR or Si rear sway bar? I know you do to mount the ITR sway bar. Also how big is the Si sway bar vs the GSR (14mm)?
Old Jul 3, 2003 | 12:59 PM
Default Re: GSR or Si sway bar (99civic_exSB)
Bump. Someone's gotta know this...
Old Jul 3, 2003 | 01:11 PM
MAD ITR 55's Avatar
The Si rear sway is 13mm
Old Jul 3, 2003 | 01:20 PM
u2civic1's Avatar
for a civic 99 ex i u will need to use the civic si bar or u can do a itr beaks kit
Old Jul 3, 2003 | 01:48 PM
Default Re: GSR or Si sway bar (u2civic1)
So to mount the 14mm GSR sway bar I will need subframe reinforcement. And with the 13mm Si bar I wouldn't? Just want to confirm...
Old Jul 3, 2003 | 02:39 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99civic_exSB &raquo;</TD></TR><TR><TD CLASS="quote">So to mount the 14mm GSR sway bar I will need subframe reinforcement. And with the 13mm Si bar I wouldn't? Just want to confirm...</TD></TR></TABLE>
you'll need to mimick whatever the Si coupe uses for mounting hardware and not the GSR's mounting hardware; as EK chassis suspensions parts differ than DC integra sus parts.
Old Jul 7, 2003 | 04:58 PM
Default Re: GSR or Si sway bar (Katman)
Good to know. I actually looked it up and the measurements are as follows:
Si
Front - 26mm
Rear - 15mm
Teg
Front - 24mm
Rear - 14mm
I'll probably do the Si conversion as this seems more straightforward.
Old Jul 7, 2003 | 05:17 PM
Mr. Choi's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99civic_exSB &raquo;</TD></TR><TR><TD CLASS="quote">Good to know. I actually looked it up and the measurements are as follows:
Si
Front - 26mm
Rear - 15mm
Teg
Front - 24mm
Rear - 14mm
I'll probably do the Si conversion as this seems more straightforward.</TD></TR></TABLE>
rear sway bar on an si is 13mm. use an integra rear sway bar if you're not serious about handling
and if on a budget.
kensei
Mar 9, 2009 05:17 AM
mr 636
May 21, 2006 07:06 PM
silverb18
19
Apr 23, 2004 12:04 AM
Timmy!
Nov 7, 2003 12:31 PM
ken-e
Jul 24, 2003 09:26 AM
