Swapping Y8 Intake Mani w/ current Z6 IM... did search already, still got ?'s
Old Jul 3, 2003 | 11:59 AM
AlphaQup's Avatar
Default Swapping Y8 Intake Mani w/ current Z6 IM... did search already, still got ?'s
Sup guys,
I just got my hands on a y8 IM and im planning on swaping it with my z6 IM. There is nothing on this topic on H-T unless someone can find something and link it here, that would be god sent for me. I need to know all the how to's on this subject. If anybody has any information it would be gladly appreciated. the other thing I found out was the problem with the IAC valve. I saw most of the post on here deal with y7 - y8 swaps but nothing about z6 - y8 swaps. HELP!!!
Old Jul 3, 2003 | 08:35 PM
AlphaQup's Avatar
Default Re: Swapping Y8 Intake Mani w/ current Z6 IM... did search already, still got ?'s (AlphaQup)
bump cause i need answers
Old Jul 3, 2003 | 10:39 PM
AlphaQup's Avatar
None of you D guys ever done this swap before ?? I'm feelin desperate now
Old Jul 4, 2003 | 07:43 AM
AlphaQup's Avatar
bump for the 4th
Old Jul 4, 2003 | 08:12 AM
krazyDOHC's Avatar
http://www.dseries.org
you'll have a better chance there
Old Jul 4, 2003 | 08:31 AM
KevronsEG's Avatar
Default Re: Swapping Y8 Intake Mani w/ current Z6 IM... did search already, still got ?'s (krazySOHC)
id di teh swap on my jdm d15b same as z6 hit em up i will help you out
Old Jul 4, 2003 | 08:49 AM
AlphaQup's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazySOHC &raquo;</TD></TR><TR><TD CLASS="quote">http://www.dseries.org
you'll have a better chance there</TD></TR></TABLE>
tried that site already... still waitin for response as well. but thanks n e ways
Old Jul 4, 2003 | 11:22 AM
AlphaQup's Avatar
I decided to take some pix so that you guys can see what i really got, because I'm also not sure if i have a AT or a MT IM. lemme know what you guys know.
top view
front view
back view
i know the pix quality aint that great either. it was dark and i had to use the flash too much reflection from the metal
Old Jul 4, 2003 | 11:38 AM
wizzards581's Avatar
hey im in ur situation too... but im having to ask about HX or EX intake manifold... this thread i will come bac.
Old Jul 4, 2003 | 11:42 AM
AlphaQup's Avatar
Default Re: Swapping Y8 Intake Mani w/ current Z6 IM... did search already, still got ?'s (wizzards581)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wizzards581 &raquo;</TD></TR><TR><TD CLASS="quote">hey im in ur situation too... but im having to ask about HX or EX intake manifold... this thread i will come bac.</TD></TR></TABLE>
Just finished posting on your thread bro
Seems like there's not that many D guys on H-T though, cause the help aint rollin in like I expected. Anybody else got feedback? Some pix would be very much appreciated as well guys.
Thanks
Modified by AlphaQup at 12:53 PM 7/4/2003
Old Jul 4, 2003 | 11:45 AM
whats xtra from that manifold then our stock on? and wats left over from the old one that that one doesnt have?? let me know.
Old Jul 4, 2003 | 11:54 AM
hatchback19's Avatar
I had this question a few months back, some guy with 15 posts helped me out. I haven't seen him around since. Very good information tho, heres what he said:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Moose &raquo;</TD></TR><TR><TD CLASS="quote">This is what you have to do ...
Make sure that you have matched the type of car it is coming from and going into as the Auto IM (Intake Manifold) is Different from the Manual IM
These are the differences between the Z6 IM (Intake manifold) and the Y8 intake manifold
Evap purge Z6- bolts to back of Z6 IM
Evap purge Y8- No mounting location on Y8 IM
Solution - Detach Z6 evap purge from Z6 IM and Zip tie to convienient bracket on firewall (becarefull of vacuum line fitting ..it breaks easily)
IACV (Idle air control valve) - No real diff - Z6 and Y8 uses same plug .... just conect to the wiring harness
IAT (Intake air temp sensor) Z6- Bolted to back of IM Plenum
IAT (Intake air temp sensor) Y8- on Intake piping before TB
Solution - detach IAT and move to intake piping or drill a hole in the Y8 plenum and Hondabond in place
TB mounting is the same, use Z6 TB ... BUT throttle cable bracket location is different between Z6 and Y8
Solution - Use Y8 throtttle cable/bracket or fabricate a new bracket or extension with angle brackets etc you pick up at HomeDepot
Lower IM support bracket is different,and does not bolt up to block
Solution, remove bracket(not really needed) or notch the lower mounting holes so that the bracket will work
Fuel rail is different .... (different bolt spacing) and the Y8 injectors are NOT compatable wuith Z6 harness
Solution - Move the Z6 injectors over to the Y8 Fuel rail
Vacuum line fittings
Y8 has one more than the Z6 .... just block it off with Honda Bond, or use as a place to mount the IAT
You will require the folowing parts
New Honda OE Y8 Intake manifold gasket
New Honda OE Throttlebody Gasket
Some HondaBond or RTV
Some Coolant to replace stuff lost when you remove the coolant lines from the TB and IACV
Bandages to fix booboo's when you remove most of the skin off your knuckles : )
Beers ... this is definately a 4 beer job
You "may" need some coolant and vacuum lines ... depending on how they survive the re and re
I highly recommend the Helms Service manual from proper assembly / dissasembly and torque settings
I highly recommend that you have a bunch of universal joints and wobble extentions for your 3/8 drive sockets ... as some of the IM bolts are B***ch to get at
That is all I can think of off the top of my head ..Have Fun !
Cheers
Moose
You should be set now, good luck!
Old Jul 4, 2003 | 12:02 PM
AlphaQup's Avatar
Default Re: Swapping Y8 Intake Mani w/ current Z6 IM... did search already, still got ?'s (hatchback19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchback19 &raquo;</TD></TR><TR><TD CLASS="quote">
You should be set now, good luck!</TD></TR></TABLE>
Damn, exactly what i was lookin for!! Good ****!! gotta love H-T
Old Jul 4, 2003 | 07:34 PM
kommon_sense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlphaQup &raquo;</TD></TR><TR><TD CLASS="quote">I decided to take some pix so that you guys can see what i really got, because I'm also not sure if i have a AT or a MT IM. lemme know what you guys know.
top view
back view
i know the pix quality aint that great either. it was dark and i had to use the flash too much reflection from the metal</TD></TR></TABLE>
That looks like a 96-98 Auto y8 IM. You can tell because the IACV is mounted on the throttle body instead of on the back of the IM.
Old Jul 4, 2003 | 07:54 PM
Happyman's Avatar
Default Re: Swapping Y8 Intake Mani w/ current Z6 IM... did search already, still got ?'s (kommon_sense)
Talk to pandaek he just helped a buddy of mine out with a y8 im onto a y7. He may be able to shine some light on the subject for you.
Old Jul 4, 2003 | 08:00 PM
Eee Pee's Avatar
Default Re: Swapping Y8 Intake Mani w/ current Z6 IM... did search already, still got ?'s (Happyman)
Moose posts every now and again on the dseries page.
Moosilla is his name over there.
Unfortunately for that site, it's having some problems because of some kids...
Old Jul 5, 2003 | 10:55 AM
AlphaQup's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kommon_sense &raquo;</TD></TR><TR><TD CLASS="quote">
That looks like a 96-98 Auto y8 IM. You can tell because the IACV is mounted on the throttle body instead of on the back of the IM.</TD></TR></TABLE>
Got any suggestions on what i should do since i have a damn AT IM instead of a MT IM...
Old Jul 5, 2003 | 11:41 PM
AlphaQup's Avatar
bump due to more answers needed
Old Jul 6, 2003 | 12:00 AM
EARLdaSQUIRREL's Avatar
official honda whore
just follow the post up above, he says its directions for an auto IM
Old Jul 6, 2003 | 02:26 AM
TheAutoboxer
Guest
Posts: n/a
Default Re: (coptzer)
like.. you still doing the install... ?
Old Jul 6, 2003 | 11:11 PM
AlphaQup's Avatar
Default Re: (menkio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by menkio &raquo;</TD></TR><TR><TD CLASS="quote">like.. you still doing the install... ?</TD></TR></TABLE>
like... yeah.... when i get all the answers.
Old Jul 7, 2003 | 04:18 AM
Happyman's Avatar
Default Re: (AlphaQup)
Seriously, talk to PandaEK. My buddy got a 96-98 Auto IM/TB and swapped it on his sol. Panda actually drove down from NY and helped him do it
Old Jul 7, 2003 | 08:09 AM
AlphaQup's Avatar
Default Re: (Happyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Happyman &raquo;</TD></TR><TR><TD CLASS="quote">Seriously, talk to PandaEK. My buddy got a 96-98 Auto IM/TB and swapped it on his sol. Panda actually drove down from NY and helped him do it </TD></TR></TABLE>
alright buddy... will do. Thanks
Old Jul 7, 2003 | 01:57 PM
Spraying93's Avatar
I did the swap to my 93 HB and i didn't even really notice that big of a difference besides throttle response. I know that you do have to drill three holes...one for the sensor on the back of the intake manifold and the other two holes you have to drill and tap the holes to hold the sensor in place...that bottom bolt on the intake manifold is a pain...you also have to rout the pcv through the runners on the y8 but that is easy...you will end up with one or two extra vacume lines but i don't remember...just email me if you have any questions about it...i just did mine like a month ago.
Old Jul 10, 2003 | 01:42 AM
AlphaQup's Avatar
One last question then im ready to do the Mani Swap. Does the z6 IACV fit the y8 IACV location on the y8 IM? I'm guessing yes, or do i have to use the IACV off of the y8 mani? I'm asking this because I have a AT y8 IM.
StuckInTexas
Feb 12, 2015 10:38 PM
gsrpedro
Dec 2, 2008 05:19 PM
Red_ED8
Apr 30, 2008 05:22 AM
Syndacate
18
Apr 24, 2006 06:55 PM
92civic_eg
Aug 18, 2004 06:24 PM
