Question about a turbocharged prelude...
Old Jul 28, 2001 | 09:30 AM
COLude's Avatar
New User
Default Question about a turbocharged prelude...
I am trying to tune my lude and was wondering where my fuel pressure should be at idle and at WOT with 6 to 8 lbs of boost. I am using a Walbro fuel pump and a Cartech FMU. My pressure is at 40psi at idle which is fine, but I have yet to play with the FMU. Also, I am running colder plugs (NGK ZFR7F-11)...where are you all gapping them? .035? Any advice would be helpful.
Old Jul 28, 2001 | 10:43 AM
TurboInteg95's Avatar
Default Re: Question about a turbocharged prelude... (COLude)
35 is okay for gap. ditch that fuel pump, it cant hang with the high pressure needed in an FMU setup,it will lean out as you start to get into some boost. start with the bleeded on the cartech all the way closed and see how it runs.
scartail
Oct 12, 2004 11:53 AM
Familycarfromhell
Feb 9, 2003 07:40 PM
ludelvr
Apr 12, 2002 11:40 PM
greyzone
Nov 14, 2001 09:14 AM
COLude
Jul 28, 2001 07:51 AM
