1998 turbo charged type R should i buy it??? help info inside!!!!
Old Jul 3, 2003 | 10:38 AM
97jrscgsr's Avatar
Default 1998 turbo charged type R should i buy it??? help info inside!!!!
1998 Integra Type-R
ENGINE: B18C5 Motor, ACT Organic Spring Dampened Clutch, Mitsubishi TDO5H-18G Turbo, ACT HD Pressure Plate, Trust Front Mount Intercooler, Skunk 2 Adj. Cam Gears, Ross 9:2 to 1 Compression Pistons, ARP Head Studs, Crower Connecting Rods, Energy Suspension Motor Mount Inserts, Total Seal Piston Rings, K&N Valve Cover Breather, Custom Test Pipe, Fluidyne Radiator, Apexi Dunk 2 1/2 inch Exhaust, HKS Super-Sequential BOV, Balanced and Blueprinted Bottom End w/Custom Bearings done by AEBS of San Diego, CA (only 2000 miles on motor)
FUEL SYSTEM: Walboro 255gal/hr Fuel Pump, AEM Adj. Fuel Pressure Regulator, AEM Fuel Rail, 720cc RC Fuel Injectors
IGNITION SYSTEM: MSD Digital 6AL Ignition w/ external Coil, MSD Rotor Cap, Magnecor 9mm Spark Plug Wires, Apex'i Iridium Spark Plugs
ELECTRONICS: Apex Power FC Fuel Managment System Tuned by XS Engineering of Huntington Beach, CA, Blitz Dual Stage Turbo Timer, Autometer A/F gauge, Greddy 60mm Boost Gauge, Boost Controller installed on Power FC Command Unit
SUSPENSION / BRAKING: Comptech .75 Drop Springs, Bilstein Sport Struts, Russell Steel Braided Brake Lines, Powerstop Slotted Rotors, Axxis Brake Pads, Comptech Strut Tower Bar
WHEELS / TIRES: Stock Championship white 15 inch Type R Rims, Nitto NT-450 tires
EXTERIOR: Carbon Fiber Hood, PIAA Headlamps, Shaved Red Acura Symbol (front and back)
INTERIOR: Type-R Seats w/red stiching, Type-R Floor mats, Red Seat belt covers, Broadway oversized rearview mirror
STEREO: Pioneer 5500 in dash cd player, Pre-wired for sound system
EXTRAS: Stock Championship white hood, Catalytic Convertor, DC Sport Short Shifter, 550cc Venom Injectors, RC 310cc Injectors any misc parts from vehicle i am willing to sell with vehicle as well.
INFO: 300+ Hp, Capable of up to 22psi of boost on the track and using race fuel., Estimated 12 second 1/4mile times
those are the spec on the car the owner told me that third gear grinds about 6000 rpm or up. but every thing else is in perfect condition
the price that we both agree on is 15700
you guys think it's a good deal? the car have a clean title
Old Jul 3, 2003 | 11:32 AM
JDMparts4u2
Guest
Posts: n/a
Default Re: 1998 turbo charged type R should i buy it??? help info inside!!!! (97jrscgsr)
I have seen this ad too looks like its ok
Old Jul 3, 2003 | 12:09 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: 1998 turbo charged type R should i buy it??? help info inside!!!! (JDMparts4u2)
720 cc injectors?
Old Jul 3, 2003 | 12:11 PM
io_burn's Avatar
New User
Default Re: 1998 turbo charged type R should i buy it??? help info inside!!!! (RealTypeR)
It sounds good as long as you're willing to take the risk of owning a car that's modded to the extreme like that. (In other words, don't expect any kind of reliability.)
Old Jul 3, 2003 | 02:47 PM
Austin's Avatar
Sounds like an old friends car...is the owner's name Leo?
Old Jul 3, 2003 | 03:11 PM
LiKe_WhOa!'s Avatar
Default Re: (Austin)
are they on honda-tech?
Old Jul 3, 2003 | 03:38 PM
97jrscgsr's Avatar
Default Re: (LiKe_WhOa!)
i am not sure if they are on honda-tech or not i found the car on ebay
Old Jul 3, 2003 | 09:32 PM
97jrscgsr's Avatar
any other suggestion any one???
Old Jul 4, 2003 | 11:24 PM
97jrscgsr's Avatar
still try to decide any suggestion???
Old Jul 4, 2003 | 11:35 PM
B2FiNiTY's Avatar
OT: There are 6 PY ITR's on ebay right now.
If you can deal with the reliability issues of the car, then I would definately check it out in person.
Old Jul 5, 2003 | 10:42 AM
Utilitarian's Avatar
Personally, I'd hate to race it; in a straight line anyway. It might be a good idea to set aside a little bit of money in case problems arise if possible. One thing to consider, if the 3rd gear grinding is more than just a little "grind" you may be paying $18-20K in the long run. Get the grind checked out before shelling out anything. Good luck and if ever in Raleigh with it, don't try to race a FBP with a Social Distortion sticker on the rear glass b/c I'm not looking to get stomped.
Old Jul 5, 2003 | 10:46 AM
uNF$@#!'s Avatar
Default Re: 1998 turbo charged type R should i buy it??? help info inside!!!! (BlackeR2000)
replacing a 3rd gear + syncros shouldnt run more than 800 dollars or so. how did you come up with 20k?
stop trying to be an alarmist please
Old Jul 5, 2003 | 11:31 AM
Default Re: 1998 turbo charged type R should i buy it??? help info inside!!!! (Soup ****)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soup **** &raquo;</TD></TR><TR><TD CLASS="quote">replacing a 3rd gear + syncros shouldnt run more than 800 dollars or so. how did you come up with 20k?
stop trying to be an alarmist please</TD></TR></TABLE>
The only reason I say this is because I was going to buy an R from a Certified Acura tech in Charlotte would encountered the same problem before selling his and he replaced 3rd and it still whined/ grinded and actually contemplated a new tranny b/c he could get it at cost. It's still a bad-*** car & if that's all it needs, so be it.
Old Jul 5, 2003 | 11:40 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
i think he meant 18-20K TOTAL, as in $500-$2500 in extra costs.
Old Jul 5, 2003 | 01:26 PM
PopeyeTheSailorMan's Avatar
$15700 is a good price.
However, do not expect this car to be completely reliable. Personally, i would never purchase a modded car like this one from anyone unless it were from a very close friend of mine and i knew it's history. In most cases like this, you are just buying someone else's problems, i know i sound optimistic but im just being honest. And i would not try pushing 22psi of boost on a non-sleeved block with only a power FC. I have heard of people hitting the 500whp marker on stock sleeves, but they were running a stand-alone and ran it on c16 octane while at the track.
Thats just my .02
Boosted B18C5
Sep 28, 2005 12:33 AM
