ls into a ek mount confusion
Old Jul 3, 2003 | 06:33 AM
EjadomaK's Avatar
Default ls into a ek mount confusion
im doing a b18b1 motor into my 96 civic. im planning on ordering a 99 Si rear mount for hasport and using a stock integra mount for the driver side. the thing is what tranny mount will bolt on if my car was automatic? i know hasport makes mount kits but will i have to modify the tranny mount and would i need to get brackets for all the mounts or just use the stock ones on the ek. also do i need the integra front tranny mount or the stock would bolt on. am i headed in the right direction on mounting??? pls help...confused
Old Jul 3, 2003 | 07:57 AM
IMALLSLO's Avatar
Default Re: ls into a ek mount confusion (EjadomaK)
A quick breakdown...assuming your using a hydro tranny for the b1 motor
driverside: order the 99 SI twin cam post mount..use original mounting bracket (dealer item)
rear: 99 SI rear L bracket(dealer item)
pass. side: use a 5 speed ek tranny bracket
front pass: use the twin cam lower tranny bracket(p72 or p30)
front driver: w/ a/c use a p54 bracket(dealer item) w/o a/c use any twin cam p30 or p72 a/c bracket
Dont waste your money on Hasport mounts when everything is a dealer item anyway. Hope that helps
Old Jan 15, 2010 | 06:14 PM
sparxx's Avatar
bump for usefullness
PwRLiMeH22
Mar 9, 2008 04:57 PM
Zx
Dec 13, 2006 07:53 AM
97civicdx
Feb 9, 2005 12:32 PM
EJCivJdM93
Feb 9, 2005 04:40 AM
92eg6
Jun 7, 2004 08:41 AM
