my stock b20/vtec in 99 hatch times. comments/suggestions? first time
Old Jul 2, 2003 | 10:49 PM
ooairewreckoo's Avatar
Default my stock b20/vtec in 99 hatch times. comments/suggestions? first time
whattup guys just got back from the track for my first night out.
r/t 1.136
60 2.323
330 6.267
1/8 9.592
mph 72.45
1000 12.442
1/4 14.900
mph 91. 36
motor is:
stock 98 b20b block
stock 94 gsr head
motor mods are:
hondata
ge fuel rail
b&m fpr
rc 310 injectors
dynoed at 162 whp
got lots of wheel hop. couldnt deflat my tires either. oh my car weighed in at 2570
comments... suggestions??
not to harsh guys it was my first time at the track.
Old Jul 3, 2003 | 04:40 AM
jeremyEG's Avatar
Default Re: my stock b20/vtec in 99 hatch times. comments/suggestions? first time (ooairewreckoo)
im curious as to what tranny you are using. id say that you need to work on your 60's a bit. try to get into the low 2.2's. but with your trap speed of only 91 i dont think you are going to get that time down very much.
and definately try to remove a good 200 lbs off your car.
but then again i took out 100lbs last time i went to the track and i couldnt even knock off 1 tenth of a second
what are you revving the motor to considering you didnt build the bottom end???
Old Jul 3, 2003 | 05:47 AM
Default Re: my stock b20/vtec in 99 hatch times. comments/suggestions? first time (jeremyEG)
im revving the motor to 8 grand sometimes even a lil more... how do i improve 60ft times?
i wish i coulda built it up a lil more but the cash just wasnt there.
Old Jul 3, 2003 | 10:20 AM
AussieK24's Avatar
That's about the norm for your setup. All motor + 2560lbs =
Old Jul 5, 2003 | 03:04 PM
smokey2.0's Avatar
that's a pretty heavy set up you have there, loose some weight on the car or make more power to improve your times. what tranny did you use? good #'s but they would be better #'s in a lighter chassis!
Old Jul 5, 2003 | 08:34 PM
LaminaR X's Avatar
Default Re: my stock b20/vtec in 99 hatch times. comments/suggestions? first time (smokey2.0)
I find it hard to believe that car weights over 2500 lbs. (96 hatch is same model,and weight 2288,with a B20 installed)I have a crx 90 that weights 2325 with me in it.The motor is a B20B block,with B20z pistons plus some block planing to bring the pistons flush.A gsr head with type r internals,and Hondata.Best et of 12.92@108,with slicks and 4.4 lsd trans
60 foot 1.85
1/8 mile of 8.20
Also A LAMINAR ported and polished head
Thanx hope that was some help
Old Jul 5, 2003 | 08:53 PM
4piston's Avatar
Default Re: my stock b20/vtec in 99 hatch times. comments/suggestions? first time (LaminaR X)
My 99 weighed 2515 off the showroom floor. Add my 230lbs to that and it was a tank.
A couple years ago I had an LSVTEC in my 99 with 10.8:1 compression and a stock 1st gen b16 head and I managed 14.3 @ 95 on my first time out. That was stock TB IM stock header...etc. I was probably making the same power as you. I think your MPH is pretty low for that setup. I would think you could squeeze 175 out of that with the Hondata. Good luck. You should be pulling 96-97mph or so with that setup depending on your elevation.
Old Jul 18, 2003 | 05:06 PM
Default Re: my stock b20/vtec in 99 hatch times. comments/suggestions? first time (4piston)
i think i can get it down a bit, well on the dyno my cams were overlaping and my top end got real weak. i shoulda bought some cam gears before we dynoed it. and i do have the low compression b20. so till next time. i doubt ill be going to the track without any new mods. but thanks for all the replies guys.
smokey... i used gsr tranny
Modified by ooairewreckoo at 7:53 AM 7/20/2003
Old Jul 23, 2003 | 04:03 PM
7thGear's Avatar
i know on stock 2000 ++ golfs, mad wheel hop was a result of too soft a suspension, the car would tilt backward so much that front tirest lost the valuble traction,
you never listed your supension mods, which are not to be forgoten.
get stiffer rear shocks and springsso that your car doesnt compress all the way at the back at start up.
also you said you had hondata, but did you fool around with it, or just install it and hope for the best? If that was the case id suggest spending a whole day at a dyno with a knowledgable programer working out the bugs.
Old Jul 28, 2003 | 09:04 PM
Default Re: my stock b20/vtec in 99 hatch times. comments/suggestions? first time (7thGear)
right now i have apexi shocks and springs.... im planning on buying eibach sport springs in a few. i will be going to the hondatech day over at e-town on the 2nd of august.
car was tuned with about 10 pulls on the dyno with a very reputable tuner here ny.
Old Jul 29, 2003 | 01:18 AM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ooairewreckoo &raquo;</TD></TR><TR><TD CLASS="quote">smokey... i used gsr tranny
[/i]</TD></TR></TABLE>
get your hands on a 00 si tranny, you'll see the difference! or buy 3/4 gears from a 00 si, take your tranny to a tranny shop and have them replace those two gears. you'll have gsr 1/2 si 3/4, and gsr 5th. that would make a nice tranny set up!
MikeNice
Aug 6, 2005 03:39 PM
URBAN TANK
May 11, 2005 08:56 PM
SamariusTA
Mar 30, 2004 05:25 PM
S@nt0s
Dec 28, 2003 06:03 PM
d mafia
Feb 5, 2002 03:55 PM
