gf's car is burning oil.. what could be the problem?
Old Jul 2, 2003 | 10:40 PM
HybridGSR1's Avatar
Default gf's car is burning oil.. what could be the problem?
my gf's 98 gsr (56k miles, previously turbo'd for 15k miles) has been burning a lot of oil, the motor still runs fine and pulls very strong except that evertime we change the oil the dipstick would show nothing.. or barely touching buttom dot. i thought it was because of the oil (mobil 10w30 synthetic) so we switched to using Neo synthetic oil, but just after about 1000 miles of driving it lost a whole quart again.. down to buttom dot.. what could be wrong?
Old Jul 2, 2003 | 10:45 PM
Spoonin's Avatar
Default Re: gf's car is burning oil.. what could be the problem? (HybridGSR1)
I would do a compression test and look for leaks (mostly around the oil line that leads to the turbo).
Old Jul 2, 2003 | 10:46 PM
OneThirtyEight's Avatar
Does the exhaust show any smoke?
Probably the oil line and the welds in the oil pan, but could be piston rings are shot.... Or too much vtecing y0!
Old Jul 2, 2003 | 10:48 PM
xSCTYGx's Avatar
try to use non-synthetic oil and see if that works...
Old Jul 2, 2003 | 11:47 PM
romeo619romeo's Avatar
Default Re: (2Gen91Teg)
use restore
Old Jul 2, 2003 | 11:51 PM
Thrillhouse's Avatar
Default Re: (romeo619romeo)
I dont know about you but i was burning mad oil too and i was using 10w30 and i changed the oil to synthetic 5w-30 and i have been fine ever since. Just a thought
Old Jul 3, 2003 | 12:01 AM
svtec's Avatar
L D E S
Default Re: (Thrillhouse)
wouldn't you burn more using a 5w-30?
Old Jul 3, 2003 | 01:29 AM
drunknmonk's Avatar
I found full syn is the way to go with the B series engines...
Old Jul 3, 2003 | 07:15 AM
shadyCTR's Avatar
Default Re: (drunknmonk)
ah a freshly beat turbo motor!
Old Jul 3, 2003 | 08:29 AM
MachAF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thrillhouse &raquo;</TD></TR><TR><TD CLASS="quote">I dont know about you but i was burning mad oil too and i was using 10w30 and i changed the oil to synthetic 5w-30 and i have been fine ever since. Just a thought</TD></TR></TABLE>
All switching to 5w should make you burn more oil. Synthetic should make you burn more oil then dino oil.
Old Jul 3, 2003 | 10:34 AM
da6vtec's Avatar
Default Re: (MachAF)
i would do a compression test...most likely your rings are going. switch to a conventional oil and maybe a thicker weight.
Old Jul 3, 2003 | 11:17 AM
dohc-nyne's Avatar
her rings are shot down....does that restore stuff really work?
Old Jul 4, 2003 | 07:37 AM
shadyCTR's Avatar
Default Re: (dohc-nyne)
**** it shoot juice in it!
kobeballer96
27
May 1, 2009 01:13 AM
redLUDEs2k1
Oct 12, 2005 10:21 AM
SOHC_MShue
Jul 25, 2005 10:36 AM
