should i use these high mileage ls rods?
Old Jul 2, 2003 | 09:18 PM
untitled's Avatar
Default should i use these high mileage ls rods?
195k on them. i might use them in a ls/vtec build up. tell me why you would or wouldnt. i am kinda leaning towards not using them but i am on a budget plus the motor isnt gonna be crazy and will most likely never see boost.
Old Jul 2, 2003 | 11:07 PM
junya16's Avatar
Default Re: should i use these high mileage ls rods? (88crx91integra)
just get em shotpeened and you should be money in the bank
Old Jul 3, 2003 | 03:31 PM
wm5holla's Avatar
Default Re: should i use these high mileage ls rods? (junya16)
what is better brand new ls rods from honda or LS rod with 90k that are shot peened
Old Jul 3, 2003 | 06:50 PM
untitled's Avatar
Default Re: should i use these high mileage ls rods? (wm5holla)
how much are brand new ls rods?
Old Jul 4, 2003 | 01:15 AM
AzN_Flava's Avatar
I read shotpeening makes ur rods .005% stronger. I believe a few people on this board, have compared shot peening rods to a twinkie. Hard on the outside but mushy still inside.
If I were you, invest in some aftermarket rods, and have them mated to oem pistons. That way, you get the arp rod bolts that come with aftermarket rods, and the nice beefier rods, to go with the oem pistons. Go with like b16/itr/ctr pistons, and your compression is like 10.9/11.4/??? i forgot. Pretty good imo.
Old Jul 4, 2003 | 09:12 AM
untitled's Avatar
Default Re: should i use these high mileage ls rods? (AzN_Flava)
yea i have pr3 pistons that on c-speed's calc bring compression to 11.6:1. i dont know what i want to do now.
Old Jul 4, 2003 | 09:35 AM
zc911's Avatar
if you are running OEM psitons, just use the stock rods, but have them modified for ARP rod bolts and you should be good to go
Old Jul 4, 2003 | 09:50 AM
wm5holla's Avatar
Default Re: should i use these high mileage ls rods? (zc911)
what is better for NOS after maket pistions or rods. i was only going to use and 50 or under shot too
Superqwak
Jul 31, 2011 06:28 PM
lsv_dc2
Jun 24, 2011 06:41 PM
Deco989
27
Jan 13, 2011 05:24 PM
ITRiWISH
Mar 27, 2008 07:05 PM
b16vtecsol
17
Nov 11, 2003 05:27 PM
