machined B16 crank pulley - VS - ctr crank pulley-- dampener differences?
Old Jul 2, 2003 | 07:48 PM
spettinger's Avatar
Default machined B16 crank pulley - VS - ctr crank pulley-- dampener differences?
my B16 pulley is in good condition, i am thinking about having the ac and power steering sections machined off and balanced, while the motor is being balanced. interested to hear reviews on machined pulleys, preferably on balanced motors. thanks.
Old Jul 3, 2003 | 12:06 AM
X2BOARD's Avatar
Default Re: machined B16 crank pulley - VS - ctr crank pulley-- dampener differences? (91hatchattack)
I recommend you speak or do this all w/ the same shop.... if done properly, I don't see why that wouldn't work.... but then again... I'm not an engine designer.
Old Jul 3, 2003 | 04:22 PM
Mr Hammond's Avatar
a/k/a Jomo
Depending on how much this would cost I would just tell you to get he UR Ultra R pulley because I love it, but you better not because then no one on here will like you and you will be haunted by the little gremlins that come out of it and destroy your motor while you are sleeping.
Old Jul 3, 2003 | 10:56 PM
y0sh1katu's Avatar
becareful w/ the pulleys that do not have harmonic balancer, if the car is your daily driver. it's not worth the ~2hp.
Old Jul 4, 2003 | 11:00 AM
raene's Avatar
Default Re: machined B16 crank pulley - VS - ctr crank pulley-- dampener differences? (Mr Milano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano &raquo;</TD></TR><TR><TD CLASS="quote">Depending on how much this would cost I would just tell you to get he UR Ultra R pulley because I love it, but you better not because then no one on here will like you and you will be haunted by the little gremlins that come out of it and destroy your motor while you are sleeping. </TD></TR></TABLE>
Bahahah... I'm sorry, but that was too funny
Old Jul 4, 2003 | 04:38 PM
indomotor's Avatar
Default Re: machined B16 crank pulley - VS - ctr crank pulley-- dampener differences? (raene)
It depends on you motor hp,rpm-the higher means more vibration.You need to have "beef" for the pulley to dampen the vibration..
Old Jul 5, 2003 | 11:54 AM
2 0 3's Avatar
Default Re: machined B16 crank pulley - VS - ctr crank pulley-- dampener differences? (indomotor)
CTR N1
Old Jul 7, 2003 | 10:04 AM
spettinger's Avatar
Default Re: machined B16 crank pulley - VS - ctr crank pulley-- dampener differences? (allmotorDA6)
i think the ctr pulley is the only option besides stock. why else do all factory race teams use ctr pulleys? and not only with hondas, but all other manufacturers use their lightest factory pulley.
Old Jul 7, 2003 | 10:11 AM
Mr Hammond's Avatar
a/k/a Jomo
No not really. Most people have lightend billet ones made with a fluid dampener built in.
Old Jul 24, 2003 | 07:23 PM
bottlefedb18c1's Avatar
Default Re: machined B16 crank pulley - VS - ctr crank pulley-- dampener differences? (kryloncrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kryloncrx &raquo;</TD></TR><TR><TD CLASS="quote">my B16 pulley is in good condition, i am thinking about having the ac and power steering sections machined off and balanced, while the motor is being balanced. interested to hear reviews on machined pulleys, preferably on balanced motors. thanks.</TD></TR></TABLE>
hey so whats going on you hidding on me?
Old Oct 23, 2003 | 01:40 AM
LHC's Avatar
LHC
juts a quick note: i just had my sir-g crank pulley lightened and according to the machine shop the a/c step has to remain in order to keep the rubber piece in place...the orig weight was like 8lbs now it weights less than 6 lbs dont know wot improvements this makes but it'll be interesting to see after my block is finished...i did this 'cose the side of it was craked and i wont run p/s and a/c either...but its nice to know that if i want a/c i can still use my oem c/p.
just thought i shared my own experience
Old Oct 23, 2003 | 02:16 AM
sleeepy808's Avatar
Modified by sleeepy808 at 3:42 AM 12/4/2003
Old Oct 23, 2003 | 05:40 AM
owen_the_soyboy's Avatar
Default Re: (sleeepy808)
REALLY?
huh.
On my oem GSR crank pulley I removed both un-necessary belt pulleys and kept the alternator pulley only. the rubber reamined in tact on that one remaining pulley and the pulley balanced very well. I also had my entire rotating assembly balanced and the car runs like a champ and starts up in a split second every time.
The lightened to one belt oem pulley weighed HALF of stock... about 6 pounds came down to 3 pounds. But that is still heavy as hell compared to an unorthodox aluminum pulley... which weighs under one pound!
Old Nov 15, 2003 | 01:29 AM
ExospeedAMcrx's Avatar
Default Re: (owen_the_soyboy)
dont modify your stock pulleys. when you can just get this one:
Old Nov 15, 2003 | 06:37 AM
WAFFLES's Avatar
Default Re: (exospeedAMcrx)
Damn, I didn't realise how expensive these things are. Exospeed, that one looks nice....maybe when I have more money though.
Old Nov 15, 2003 | 11:07 PM
Default Re: (WAFFLES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WAFFLES &raquo;</TD></TR><TR><TD CLASS="quote">Damn, I didn't realise how expensive these things are. Exospeed, that one looks nice....maybe when I have more money though.</TD></TR></TABLE>
the only other SFI approved Pulley for the B series is about $400 i heard and thats the ATI brand
Old Nov 30, 2003 | 07:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91hatchattack &raquo;</TD></TR><TR><TD CLASS="quote">my B16 pulley is in good condition, i am thinking about having the ac and power steering sections machined off and balanced, while the motor is being balanced. interested to hear reviews on machined pulleys, preferably on balanced motors. thanks.</TD></TR></TABLE>
i hope you are not still out there ripping other people off there bud it will catch up to you sooner or later
and changing you name around is not going to keep others from finding you on here
you are still a scammer
groundzerocivic
Jul 27, 2008 07:21 PM
:Andrew
Mar 10, 2007 03:40 PM
IGotNoSwap
21
Sep 27, 2005 08:17 PM
stivic
May 7, 2005 08:56 PM
gtowni3
Oct 15, 2004 08:29 PM
