Spun Bearing
I was looking into buying a used block, and the seller said that he thinks he has a spun bearing.
What are the symptoms of a spun bearing? Could the motor run with a spun bearing?
How would you repair a motor with a spun bearing? I assume that you will have to remachine the block/rod and crank.
Fishy_hondaman
Engine Machining & Assembly
Sep 18, 2016 10:05 PM
HickamHatch
Dec 17, 2005 04:10 PM
