Piston Rod Combo's for 85mm street motor...HELP!
Old Jul 2, 2003 | 04:25 PM
MaxBoost's Avatar
New User
Default Piston Rod Combo's for 85mm street motor...HELP!
I have a GE Sleeved LS block, and im going to be using a ITR head..
What companies shock 85mm pistons, around 12.0:1 compression, <u>WITH</u> relocated wrist pin setup??
I will be using EF-1 M24E cams so I will need to be able to rev the **** out of this thing, that's why i want/need the relocated wrist pins.
If I get JE to custom make the pistons for me, what do I ask for?? How far should they move the hole for the pin? How much longer is the rod? Does Eagle shelf a rod for pistons with relocated wrist pins? I'm planning on using the new eagle rods with the 10mm upgraded rod bolts..
Old Jul 2, 2003 | 04:35 PM
H25's Avatar
H25
Default Re: Piston Rod Combo's for 85mm street motor...HELP! (MaxBoost)
eagle rods and any forged 85mm pistons will be fine. you might start to chase your tail if you get into changing rod stroke. we build ls/vtec and never had any problems making power or running fast et's. i would strongly reccomend not messing with the geometry of your motor. keep it simple. and you wont have any problems. good luck. btw we have a clean 95 ls crank for sale. pm if you havent found one yet. later.
Old Jul 2, 2003 | 10:09 PM
MaxBoost's Avatar
New User
Default Re: Piston Rod Combo's for 85mm street motor...HELP! (LuckyRacing)
Do you think that with stock LS geometry, the motor will be able to take high rpms?? The cams have lots of duration and i'd think they'd make power to over 9800-10,000rpms..i want to make sure the block can take it... what are the set backs of moving yur wrist pin up?? what are the cons, I've never heard of any drawbacks, i may just go with stock geometry cus I can get shelf pistons and rods..and not custom crap that takes forever to make..
Old Jul 2, 2003 | 10:48 PM
10K2HVN's Avatar
^^click^^
All the way down..the second to that last picture....
Old Jul 3, 2003 | 01:54 AM
Rocket's Avatar
Default Re: Piston Rod Combo's for 85mm street motor...HELP! (10K2HVN)
I looking to have some short skirt side forged pistons pretty soon. I'll let you guys know what I come up with.
Old Jul 3, 2003 | 09:17 AM
MaxBoost's Avatar
New User
Default Re: Piston Rod Combo's for 85mm street motor...HELP! (Rocket)
So, looks like endyn has what I want, but now Im curious as to what the cons are of using longer rods and pistons with relocated wrist pins.
Old Jul 3, 2003 | 09:47 AM
zc911's Avatar
so does http://www.importbuilders.com
Old Jul 3, 2003 | 10:06 AM
MaxBoost's Avatar
New User
Default Re: Piston Rod Combo's for 85mm street motor...HELP! (zc911)
I would order from ImportBuilders, but to be quite honest I don't know how. They don't have a phone number, and when I email sales@importbuilders.com asking to order pistons, they never reply.. Maybe one day they will get a phone at the shop so they can make more business, i mean it's ridiculous that I want to buy pistons and rods from them, but can't seem to do it.
Old Jul 3, 2003 | 11:44 AM
indomotor's Avatar
I'm running .137 longer Eagle rods and 13:1 pistons in my B20 vtec.I got the set up from endyn,the pistons' skirt very skinny but stable at high rpm.Just to let you know I'm very happy with the result.
Old Jul 3, 2003 | 12:28 PM
MackSpeed-616's Avatar
Default Re: Piston Rod Combo's for 85mm street motor...HELP! (indomotor)
i am using the probe ultra lights and they work very well in my setup.
as far as pistons, definetly check with importbuilders theyll hook you up.
Old Jul 3, 2003 | 01:13 PM
MaxBoost's Avatar
New User
Default Re: Piston Rod Combo's for 85mm street motor...HELP! (BustaNutt-616)
I actually wanted to run Probe rods, but I only know of one place that sells them, and that place doesn't return emails or private messages thru HT (importbuilders) Jeff if you read this please send me a PM so I can get this stuff from you.
Does probe have rods that are .137 longer?? If so I will consider going with Endyn Wiseco and probe rods, or perhaps custom JE's and eagle's w/ upgraded rod bolt. Also considering Tiawanese made rods being offered by Rocket (EF1)
Old Jul 3, 2003 | 01:34 PM
Rocket's Avatar
Probes don't come in 0.137 longer. Flatlanderrancing.com sells them if you are interested.
Old Jul 3, 2003 | 11:04 PM
y0sh1katu's Avatar
What would the R/S ratio be if the rod is .137 longer?
Old Jul 3, 2003 | 11:10 PM
10K2HVN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaxBoost &raquo;</TD></TR><TR><TD CLASS="quote">I Does probe have rods that are .137 longer?? If so I will consider going with Endyn Wiseco and probe rods, or perhaps custom JE's and eagle's w/ upgraded rod bolt. Also considering Tiawanese made rods being offered by Rocket (EF1)</TD></TR></TABLE>
Eagle's and Crower Econ's are forged overseas too....
Old Jul 3, 2003 | 11:46 PM
10K2HVN's Avatar
Default Re: Piston Rod Combo's for 85mm street motor...HELP! (yoshikatu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yoshikatu &raquo;</TD></TR><TR><TD CLASS="quote">What would the R/S ratio be if the rod is .137 longer?</TD></TR></TABLE>
i just did this on my notepad..cut..paste.....
===========Rod Lenth=============
B18B = 5.394" = 137.0076 mm
B18C = 5.433" = 137.9982 mm
=============Stroke==============
B18B = 89 mm
B18C = 87.2 mm
==========Rod/Stroke Ratio==========
B18B = 1.54
B18C = 1.58
=========Custom Plus Lenths=========
.250" = 6.35 mm (Endyn)
.137" = 3.4798 mm
=========Custom Rods Endyn=========
B18B = 137.0076 + 6.35 = 143.0076
B18C = 137.9982 + 6.35 = 143.9982
========Endyn Rod/Stroke Ratio========
B18B = 143.0076 / 89 = 1.60682 ~ 1.61
B18C = 143.9982 / 87.2 = 1.65135 ~ 1.65
========Custom Rods +.137"==========
B18B = 137.0076 + 3.4798 = 140.4874
B18C = 137.9982 + 3.4798 = 141.4780
=======Custom Rod/Stroke Ratio========
B18B = 140.4874 / 89 = 1.5785 ~ 1.58
B18C = 141.478 / 87.2 = 1.6224 ~ 1.62
Modified by 10K2HVN at 4:02 PM 7/5/2003
Old Jul 4, 2003 | 07:37 AM
zc911's Avatar
thats odd, jeff ususally gets back pretty quick
I sell them too, but you can find better deals from guys in the US than ordering from me,,i am just chepaer than other Canadian guys
Old Jul 4, 2003 | 08:52 PM
Ivan's Avatar
senior gold member
so the longer rods give you gsr type r/s ratio. seems minimal to me. I wonder if the wrist pin being in the oil control ring groove affects any long term reliability.
Old Jul 5, 2003 | 11:37 AM
Rocket's Avatar
Default Re: Piston Rod Combo's for 85mm street motor...HELP! (Ivan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan &raquo;</TD></TR><TR><TD CLASS="quote">so the longer rods give you gsr type r/s ratio. seems minimal to me. I wonder if the wrist pin being in the oil control ring groove affects any long term reliability.</TD></TR></TABLE>
Going from 1.54 to 1.58 r/s actually makes your top end pull last longer, everything else being equal.
Old Jul 5, 2003 | 02:32 PM
ENDYN's Avatar
The Old One
We have several sets of +.137" Crower billet rods on the way. They'll be lighter than the standard-issue Crowers as they're meant for NA high HP and RPM operation with our pistons.
Old Jul 5, 2003 | 04:49 PM
10K2HVN's Avatar
Default Re: Piston Rod Combo's for 85mm street motor...HELP! (Woofer)
im bored.....
===B18A/B/C B20B/Z Standard Deck Height===
8.347 inch = 212.0138 millimeter
=============Rod Lenth=============
B18A/B = 5.394 inch = 137.0076 millimeter
==============Stroke==============
B18A/B = 3.504 inch = 89.0016 millimeter
==========Dart Tall Deck B20==========
8.9 inch = 226.06 millimeter
=======Differents Between Blocks========
226.06 - 212.0138 = 14.0462 mm
========New Standard-Pin Rods=========
137.0076 + 14.0462 = 151.0538 mm
=========New Rod/Stroke Ratio=========
151.0538 / 89 = 1.69723370786516853932584269662921 ~ 1.70
========With Crower 92mm Crank========
89 / 2 = 44.5
92 / 2 = 46
46 - 44.5 = 1.5
151.0538 - 1.5 = 149.5538
149.5538 / 92 = 1.62558478260869565217397304304347826 ~ 1.63
=========With Pins in Oil Rings==========
.250" = 6.35 mm
151.0538 + 6.35 = 157.4038
157.4038 / 89 = 1.76858202247191011235955056179775 ~ 1.77
149.5538 + 6.35 = 155.9038
155.9038 / 92 = 1.69460652173913043478260869565217 ~ 1.69
Old Jul 7, 2003 | 11:50 PM
ALLMTRWHORE's Avatar
well think of it this way! 1mm up on the pin hole 1 mm longer on the rod and so and so on and well if you had a 95 mm crank you could use your ls spec crower rods but you would have to move the pin up 3mm becuase 3mm up and 3mm down of the sroke! better rod ratio too! did I let out a secret OH well! common sense that's all! happy tuning bro! keep me posted<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaxBoost &raquo;</TD></TR><TR><TD CLASS="quote">I have a GE Sleeved LS block, and im going to be using a ITR head..
If I get JE to custom make the pistons for me, what do I ask for?? How far should they move the hole for the pin? How much longer is the rod? Does Eagle shelf a rod for pistons with relocated wrist pins? I'm planning on using the new eagle rods with the 10mm upgraded rod bolts..</TD></TR></TABLE>
Phatch99
Apr 10, 2005 03:28 PM
stevescivic
Jan 30, 2005 04:20 AM
turboteggsr
Jun 12, 2004 12:20 AM
Yellb16crxsi
May 19, 2003 12:19 PM
