header gasket - how tights?
Old Jul 2, 2003 | 04:03 PM
pineapplemike's Avatar
Default header gasket - how tights?
does anyone know how tight the header gasket should be? what torque?
do i need to use rtv silicon sealant?
if i do, does can i use rtv blue by permanex?
thanks
Old Jul 2, 2003 | 04:12 PM
Default Re: header gasket - how tights? (supmike)
do i need to drive it around to let it seal or anything like that? or should it not leak at all anyways?
Old Jul 2, 2003 | 05:18 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
just stick the gasket onto the studs, put the header on, and torque to 23 lb-ft. Don't need to add anything to the gasket.
Old Jul 2, 2003 | 05:38 PM
Default Re: header gasket - how tights? (PatrickGSR94)
what happens if you overtighten? if you break a bolt off, what should you do?
if i did more than 23 lb ft, should i bother loosening if its not leaking?
Old Jul 2, 2003 | 05:53 PM
Community Builder
if it's more than 23 and it's not broken, don't mess with it.
Old Jul 2, 2003 | 10:02 PM
.RJ's Avatar
.RJ
if a stud breaks then you'll have to drill it out if its broken inside the head. If its poking out of the head, use vice grips to turn it out.
be careful when you do remove them if they are over-tight. Put the socket on the nut and hit it *lightly* with a small hammer until it breaks loose rather than laying into it w/ a breaker bar, which will snap the stud.
Old Jul 2, 2003 | 10:05 PM
P1mpSlap's Avatar
Default Re: header gasket - how tights? (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">be careful when you do remove them if they are over-tight. Put the socket on the nut and hit it *lightly* with a small hammer until it breaks loose rather than laying into it w/ a breaker bar, which will snap the stud.</TD></TR></TABLE>
good call
Also retorque in the correct pattern inside out/criss cross
Old Jul 3, 2003 | 02:03 AM
xteg95's Avatar
Default Re: header gasket - how tights? (P1mpSlap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap &raquo;</TD></TR><TR><TD CLASS="quote">
Also retorque in the correct pattern inside out/criss cross</TD></TR></TABLE>
definately do that if you didnt already.
jay di em02
Jan 28, 2007 11:00 AM
vexx7001
Dec 15, 2005 10:44 PM
VTecLude1994
Jun 27, 2005 10:04 AM
Paluce
May 26, 2005 02:25 PM
b16a1civichb
Nov 30, 2002 07:49 PM
