post pics of ur block
Old Jul 2, 2003 | 01:58 PM
wm5holla's Avatar
Default post pics of ur block
i cant rember the name of the post, but i was tryin to find some pics of blocks! search anit helpin me at all
Old Jul 2, 2003 | 06:12 PM
b19coupe's Avatar
Default Re: post pics of ur block (wm5holla)
GE sleeved GSR block-84mm JE 12.5:1 pistons.
Old Jul 2, 2003 | 09:03 PM
deepgreengsr's Avatar
Here is my blown B18c1 motor with 117xxx miles. The rod cap went through the block and through the radiator. I found it in the shroud. the piston was below the dowel pin in 1billlion pieces. and the rod was bent. Some valves droped and the head got mangled. http://www23.brinkster.com/mikecollins\motor.html pictures.
Old Jul 2, 2003 | 09:43 PM
dwn-shift's Avatar
Default Re: post pics of ur block (deepgreengsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deepgreengsr &raquo;</TD></TR><TR><TD CLASS="quote">Here is my blown B18c1 motor with 117xxx miles. The rod cap went through the block and through the radiator. I found it in the shroud. the piston was below the dowel pin in 1billlion pieces. and the rod was bent. Some valves droped and the head got mangled. http://www23.brinkster.com/mikecollins\motor.html pictures.</TD></TR></TABLE>
You just gave that motor some Character
Old Jul 2, 2003 | 10:46 PM
wm5holla's Avatar
Default Re: post pics of ur block (dwn-shift)
can do u clean up a block at home? thats gsr was too clean, you could eat off of it!
Old Jul 2, 2003 | 11:11 PM
Sonny's Avatar
Default Re: post pics of ur block (b19coupe)
87 Integra block, Endyn pistons, Eagle rods, ACL bearings, and block posts.
Sonny
Old Jul 3, 2003 | 09:23 AM
wm5holla's Avatar
Default Re: post pics of ur block (Sonny)
how did u guys get so clean? im a lil scared to put cleaning **** in the walls or on my pitions!
Old Jul 3, 2003 | 01:21 PM
b19coupe's Avatar
Golden Eagle did that block for me, I don't know what they use, but the block looks squeaky clean.
Old Jul 4, 2003 | 08:22 AM
Sonny's Avatar
Castrol Super Clean (big purple bottle...get it from Walmart for about 6 bucks) does an AMAZING job on oil and dirt. Sure, you can use stuff like brake cleaner or acetone, but that stuff is really toxic.
The Castrol stuff is amazing for something that is not a solvent.
Sonny
Old Jul 4, 2003 | 08:40 AM
dwn-shift's Avatar
I used a wire wheel on my one of my blocks and that came out really shinny, more of a polished look. For that to work you still have to clean the block from dirt and oil.
Old Jul 4, 2003 | 09:55 AM
martini's Avatar
nothing special, just a regular B18B
http://www.fatboyraceworks.com...6.jpg
Old Jul 4, 2003 | 10:23 AM
Vinceg99's Avatar
Default Re: post pics of ur block (martini)
Depending on what you do with your motor if you have it sent out to have something done to it more than likely they can hot tank it for you which will get it sparkling clean!! Also you can use any kind of cleaner you want as long as its safe for use on aluminum. I did a little of both with a wire brush and some cleaners. I will have a pic up soon hopefully!!
Old Jul 4, 2003 | 11:57 AM
skribblah's Avatar
Default Re: post pics of ur block (Vinceg99)
(being a smartass)
Old Jul 4, 2003 | 12:27 PM
JDMCRX's Avatar
Default Re: post pics of ur block (skribblah)
What works real good to clean is SIMPLE GREEN the consentrated one it works very good
Old Jul 4, 2003 | 06:23 PM
turbodsmpower's Avatar
Default Re: post pics of ur block (JDMCRX)
heres mine i had it hot tanked at the machine shop the painted and cleared the engine to insure future clean up is easy
http://www.we-todd-did-racing....TU0MQ==
b18sihatch
Apr 17, 2007 06:28 PM
black99x
15
Aug 10, 2006 03:06 PM
mugenhatch92
Apr 8, 2006 03:42 PM
blk02ep3
Dec 9, 2004 12:46 PM
fullracegsr
Apr 6, 2004 05:37 PM
