What kind of sand paper?
I think he's talking about that stuff you use to clean your dishes. The green stuff is used on transmission stuff (at least at the shop I worked at), so I'm sure it's cool for body work!
You should use some wet and dry sandapaper 400 grit and lots of water. If the lip has any little chips at all you should use 320 grit and lots of water. I would also advise cleaning it before and after with 3M wax and gease remover. The cleaner the better.
