Power to weight ratio
Old Jul 2, 2003 | 08:12 AM
93si's Avatar
Default Power to weight ratio
How much power to weight ration will it take to get a 93 si to run between high 11s and low 12s. Just want to get and idea how much power and weight I should set my goals to be
Old Jul 2, 2003 | 10:17 AM
AussieK24's Avatar
Default Re: Power to weight ratio (93si)
230 to 260 whp + 1800 to 2200lbs = your target
Old Jul 2, 2003 | 10:53 AM
80884's Avatar
Default Re: Power to weight ratio (AussieB20vtec)
http://www.4racecars.com/calcu....html
Old Jul 2, 2003 | 11:22 AM
DIRep972's Avatar
Smarter than you
about 1 hp per 8lbs of wieght
Old Jul 2, 2003 | 12:45 PM
93si's Avatar
thanks guys. my goal is to get the car to weight 2050 with me in it and to make 220whp all motor
Old Jul 2, 2003 | 08:09 PM
jeremyEG's Avatar
Default Re: (93si)
sounds like it would be good for mid 12's if you hit your goal.
Old Jul 2, 2003 | 08:11 PM
jeremyEG's Avatar
Default Re: (jeremyEG)
i forgot to ask how you are planning on making the si weigh that little with you in it?? i have the same car and would love to get it anywhere near that weight without me in it.
Old Jul 3, 2003 | 07:22 AM
Charlie Moua's Avatar
Default Re: Power to weight ratio (nouseforaname)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nouseforaname &raquo;</TD></TR><TR><TD CLASS="quote">about 1 hp per 8lbs of wieght</TD></TR></TABLE>
how did you calculate that? what's the formula
Old Jul 3, 2003 | 10:38 AM
93si's Avatar
jeremyEG,
Yeah planning to get it down to 2050 with me in it, but its going to be hard.
Got all the basics out:
tar, carpet, rear seats, fire wall insulation, spare tire, cf hood, AC, power steering, cruise control, SRS system
Next is going to be rear panels, sunroof glass changed to lexan, fiber glass hatchdoor, AC Compresor under the dash and weight it and see where I am at.
What have you done so far. Any other ideas.
Old Jul 3, 2003 | 10:55 AM
boarderdudeh's Avatar
too bad we only hit the 14s with our dohc's
Old Jul 3, 2003 | 10:04 PM
jeremyEG's Avatar
Default Re: (93si)
i have everything done that you have listed except for the lexan sunroof and fiberglass hatch. i also removed the bumper supports, removed the power mirrors, have fairly light wheels and momo bucket seats that weigh 11lbs each.
if you are serious about weighing in at roughly 1850-1900, you will need to remove the whole sunroof assembly, lexan windows all around, get fiberglass doors, a 1 piece front end, get rid of the dash and everything except for a driver seat, a small fuel tank, a lightweight battery, and maybee a narrowed drag rear end.
Old Jul 4, 2003 | 06:58 AM
AussieK24's Avatar
If your going to go to all that trouble, you'd be better off starting with a lighter car ie EF
Old Jul 7, 2003 | 07:23 AM
93si's Avatar
I wish I would of done that from the beginning. I have to much invested in the car already.
matto2413
Jan 13, 2005 03:39 PM
Scean
Mar 23, 2004 10:37 AM
HavokB18
Jun 21, 2003 06:54 AM
simple4012
Apr 18, 2003 01:01 AM
GreenR
Jun 18, 2002 08:33 AM
