squeel from the engine when i take off.....timing belt loose?
Old Jul 2, 2003 | 08:09 AM
patdemps's Avatar
Default squeel from the engine when i take off.....timing belt loose?
When i take off there is a squeel from one of the belts. the timing belt was just changed 5 days ago so could it be loose? thanks.
Old Jul 2, 2003 | 08:27 AM
H22 CD5's Avatar
it can't be the timing belt b/c the timing belt can't slip. it has teeth. what it could be is your tires breaking traction and peeling out when you take off??
It's an accessory belt that just needs to be tightened. alternator,power steering,a/c belt. check the tension on those and adjust.
Old Jul 2, 2003 | 12:42 PM
betsuni's Avatar
Default Re: (H22 CD5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22 CD5 &raquo;</TD></TR><TR><TD CLASS="quote">
It's an accessory belt that just needs to be tightened. alternator,power steering,a/c belt. check the tension on those and adjust.</TD></TR></TABLE>
yes!
Old Jul 2, 2003 | 12:54 PM
Katman's Avatar
Default Re: squeel from the engine when i take off.....timing belt loose? (patdemps)
check your alternator, power steering, or A/C belts. I'm betting its your alternator belt. Tighten it up and the squeeling should go away.
You can by a lube-spray for your belt(s) at an automotive parts store too.
Old Jul 2, 2003 | 01:38 PM
Mohudsolo's Avatar
Default Re: squeel from the engine when i take off.....timing belt loose? (Katman)
Remember, all the accessory belts have to come off to do the timing belt. One probably was not tightened properly. Check the tensioner pulley for the AC. If it comes off it takes the PS belt with it then jambs against the crank pulley and breaks it. Mine was squeeling at low speed, then came off and did the above.
Check all the belts and assorted bolts that tighten them just in case.
Old Jul 2, 2003 | 06:25 PM
patdemps's Avatar
Default Re: squeel from the engine when i take off.....timing belt loose? (Mohudsolo)
thanks guys. I think i figured out which one was loose today while checking through the engine. Im going to tighten it tomorrow and I should be all set. I removed the a/c, cruise and p/s so that got rid of those to worry about. Its the alternator belt....I appreciate it guys!!
JasonST
Sep 6, 2013 10:02 AM
JDMtype Eg6
Feb 18, 2007 05:45 AM
Benhawk
Jan 29, 2007 11:49 AM
snapper1978
Oct 18, 2006 09:21 AM
blayzenazn
Feb 18, 2002 07:51 AM
