stock ls questions
Old Jul 2, 2003 | 06:43 AM
evol_crx_sir's Avatar
Default stock ls questions
what should a stock ls run on the track if tuned right ?
Are there any tricks or tips that can be told to help the time gett better?
Well a 4-1 header give me more top end or just mess my engine breathing all up?
Old Jul 2, 2003 | 07:19 AM
dohc-nyne's Avatar
16.....if ur lucky high 15?
Old Jul 2, 2003 | 07:33 AM
Default Re: (dohc-nyne)
but no tips on how to get going any faster and what about the 4-1 header what is that going to do for me
Old Jul 2, 2003 | 07:36 AM
RacerXintegra2k's Avatar
Default Re: (evol_crx_sir)
a header alone wont really help you gotta setup a package to ur car like what u want ? if u want top end get a cai 4-1 and a good exhaust that will give you some. myself i went with a short ram and a 4-2-1 and a type r exhaust.
Old Jul 2, 2003 | 08:09 AM
dohc-nyne's Avatar
if thats all ur focused on is 1/4 mile time then go with 4-2-1 header...
Old Jul 2, 2003 | 08:23 AM
dip-set's Avatar
i broke in to the high 15"s my first time at the track with my ls with only a k&n drop in,street tires about 60 percent thread and full interior...launched at 3000...
Old Jul 2, 2003 | 08:28 AM
95hbMatt's Avatar
Default Re: (teg-your-it)
i ran a 15.02 @93mph...coulda broke into the high 14s but didn't get another run in....
EDIT: nevermind....i have an LS swap in an EG...
Old Jul 2, 2003 | 08:38 AM
dohc-nyne's Avatar
Default Re: (95hbMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95hbMatt &raquo;</TD></TR><TR><TD CLASS="quote">i ran a 15.02 @93mph...coulda broke into the high 14s but didn't get another run in....
EDIT: nevermind....i have an LS swap in an EG... </TD></TR></TABLE>
15.02 stock??? stock tires?
Old Jul 2, 2003 | 08:46 AM
b18b98's Avatar
I ran a 15.4@88 with i/h/e dropped on skunk2s with stock tires. Bone stock LS will probably run 16.2 - 15.7 depending on driver, weather and track conditions.
Old Jul 2, 2003 | 09:11 AM
dohc-nyne's Avatar
Default Re: (b18b98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18b98 &raquo;</TD></TR><TR><TD CLASS="quote">I ran a 15.4@88 with i/h/e dropped on skunk2s with stock tires. Bone stock LS will probably run 16.2 - 15.7 depending on driver, weather and track conditions.</TD></TR></TABLE>
i have the same set up as u.. + 6 puck clutch and lightened flywheel and azenis...i would be happy if i broke into 14's ill find out in two weeks...
Old Jul 2, 2003 | 09:27 AM
95hbMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohc-nyne &raquo;</TD></TR><TR><TD CLASS="quote">
15.02 stock??? stock tires?</TD></TR></TABLE>
I have an AEM CAI/USDM ITR header/2.25" testpipe/2.25" custom exhaust(kteller8)/ACT HDSS flywheel/koni yellow full coilovers/yokahama A539s(street tires)
r/t 1.026
60' 2.310
330 6.339
1/8 9.685
MPH 75.12
1000 12.554
1/4 15.025
MPH 93.22
300ft above sea level
I should break 14s with a little more practice!
Old Jul 2, 2003 | 12:39 PM
DK4200's Avatar
if your leaving it stock then here are a few tips that won't cost anything...
Advance Timing
Gut Interior (mostly from front seats back)
Take off P/S belt
Lower your tire pressure (20-25 psi)
Practice Practice Practice
Stock LS will run low 16's - depending where you live, sea-level, weather and track conditons all being perfect you might hit 15's
Teg LS
Jun 29, 2008 06:53 PM
integra99blue
Jul 22, 2004 09:51 PM
RacerXintegra2k
Oct 8, 2002 02:11 PM
The Rob
Mar 20, 2002 08:05 AM
LSBlackInteg
Nov 19, 2001 01:30 PM
