Going to the drag strip tomorrow, tire pressure question.
Old Jul 2, 2003 | 01:54 AM
2000 Integra R #760's Avatar
Default Going to the drag strip tomorrow, tire pressure question.
What's up guys. I am going to go to the drag strip tomorrow and i have a tire pressure question. I have 16" SW388's with Yokohama ADVAN AO38's Soft compound in 215/45/16. What tire presure would you guys recommend? I am currently running 41psi for the street. Thanks in advance.
Old Jul 2, 2003 | 03:08 AM
00 FBP ItR's Avatar
Default Re: Going to the drag strip tomorrow, tire pressure question. (2000 Integra R #760)
8-12psi
BTW John... i think we ALL know you got sw388's.. no need to brag.. fcukin' sp00m wh0re
GL @ the tracks btw...
Old Jul 2, 2003 | 08:17 AM
Default Re: Going to the drag strip tomorrow, tire pressure question. (00 FBP ItR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00 FBP ItR &raquo;</TD></TR><TR><TD CLASS="quote">8-12psi
GL @ the tracks btw...</TD></TR></TABLE>
HAHA Toan.....8-12 psi really . Thanks I hope I get a good run in
Old Jul 2, 2003 | 08:21 AM
Another question.....the advans are at their wear bars.....do you think they will hold up or should I switch to azenis?
Old Jul 2, 2003 | 08:26 AM
RTW DC2R's Avatar
Im guessing that those are street tires. I wouldnt run them that low but thats just my opinion. I ran last week on street tires at about 17psi and my rim was almost riding on the ground. But again thats just me. Good luck and report back to us what kinda timeslips you run
Old Jul 2, 2003 | 08:31 AM
Default Re: Going to the drag strip tomorrow, tire pressure question. (RTW DC2)
They are not street tires...at least they are not made to be. Here is a pic..
Old Jul 2, 2003 | 08:42 AM
JohnnyBoy's Avatar
Around 20-25psi.
Old Jul 2, 2003 | 08:47 AM
Default Re: (JohnnyBoy)
Wow that's a big range guys......8-12, 17 , 20-25psi...Um i guess I'll just play around with them.
Thanks for the recommendations. It should definetly help me out.
Old Jul 2, 2003 | 08:50 AM
RTW DC2R's Avatar
Default Re: (2000 Integra R #760)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000 Integra R #760 &raquo;</TD></TR><TR><TD CLASS="quote">Wow that's a big range guys......8-12, 17 , 20-25psi...Um i guess I'll just play around with them.
Thanks for the recommendations. It should definetly help me out.</TD></TR></TABLE>
Trying different things is the key. Normally I run about 35-40PSI on the street, so for the strip I lowered to around 20. I was still getting some wheel hop so I lowered a bit more and wheel hop went away so thats where I left it. It was really hot out, and my Kumhos seemed to like to be heated up and they actually got pretty sticky. Some tires like to be heated up, and others dont. It just depends on the tire and pressure and track. Just gotta play around with it a bit and see what seems to work best.
Old Jul 2, 2003 | 09:03 AM
nEoMuGen's Avatar
Default Re: (RTW DC2)
I would suggest you headover to the Drag Racing forum for this one.
I lowered to around 18psi on my Dunlop SP5000 All-Seasons and ran a low 14...
Old Jul 2, 2003 | 09:23 AM
JUN JDM's Avatar
Old Jul 2, 2003 | 10:11 AM
SoCal ITR's Avatar
Default Re: (JUN JDM)
All my best times have been at 17 psi
I've never gone below 16.
Old Jul 2, 2003 | 10:45 AM
Mike95lude's Avatar
I've heard to not really lower your tire pressure much with street tires. It will lower your trap speed and provide minimal benefits on street tires.
Old Jul 2, 2003 | 10:55 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
I run 20psi in my SO-3's which are stiff sidewall tires as well. Although I'm sure not as stiff as yours. I've pulled 2.0 60' with them if that helps. I recommend maybe going a tad lower, but I wouldn't dip below 17psi since they aren't drag radials/slicks.
Old Jul 2, 2003 | 12:41 PM
tjtruong's Avatar
New User
Default Re: Going to the drag strip tomorrow, tire pressure question. (ActiveAero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ActiveAero &raquo;</TD></TR><TR><TD CLASS="quote">I run 20psi in my SO-3's which are stiff sidewall tires as well. Although I'm sure not as stiff as yours. I've pulled 2.0 60' with them if that helps. I recommend maybe going a tad lower, but I wouldn't dip below 17psi since they aren't drag radials/slicks.</TD></TR></TABLE>
exactly. I would try 22-24 to start with and if you still get too much wheel hop just lower it to a tad. We'll play with it today jon , don't worry. .
tj
Old Jul 2, 2003 | 12:47 PM
RTW DC2R's Avatar
Did you heat them up in the burnout box or no?
Old Jul 2, 2003 | 12:59 PM
SoCal ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">
Did you heat them up in the burnout box or no?</TD></TR></TABLE>
Generally I just do a short little burnout to get the tires clean and warm them up just a tad, otherwise they'll get greasy if you do it too much.
Old Jul 2, 2003 | 01:00 PM
01ITR#700's Avatar
This is what I do on Street tires:
-Set pressure in front to 21-22 psi
-Set pressure in rear to 45psi
-DO NOT heat them up in the water
-do a quick little burnout in the "dry" to knock off all the pebbles/sand etc.
HTH
M
Old Jul 2, 2003 | 01:05 PM
tjtruong's Avatar
New User
Default Re: Going to the drag strip tomorrow, tire pressure question. (01ITR#700)
i burn out until the car pulls forward alittle. Doesn't take too long
Old Jul 3, 2003 | 12:58 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
NO! Don't heat them up in the water box. Bad news for street tires, because there will be water caught between the treads.
However, I do a pretty good dry burnout before I pull up to stage. Cleans off the tires and puts a tad bit of heat into them.
Old Jul 3, 2003 | 01:04 PM
skafia's Avatar
25 Year Member
Just keep lowering the pressure until you stop hopping.
Old Jul 3, 2003 | 01:50 PM
done's Avatar
Default Re: Going to the drag strip tomorrow, tire pressure question. (skafia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skafia &raquo;</TD></TR><TR><TD CLASS="quote">Just keep lowering the pressure until you stop hopping.</TD></TR></TABLE>
Old Jul 3, 2003 | 01:54 PM
jond's Avatar
Default Re: Going to the drag strip tomorrow, tire pressure question. (Mike95lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike95lude &raquo;</TD></TR><TR><TD CLASS="quote">I've heard to not really lower your tire pressure much with street tires. It will lower your trap speed and provide minimal benefits on street tires.</TD></TR></TABLE>
Same here. I thought that with stiff sidewall tires, that lowering the pressure will cause the inside of the tire to not make as much contact with the ground.
Old Jul 3, 2003 | 02:05 PM
Reid's Avatar
Global Moderator
Default Re: Going to the drag strip tomorrow, tire pressure question. (jond)
Don't you have tires with softer sidewalls?
Use those.
Old Jul 3, 2003 | 02:12 PM
Unsung's Avatar
Default Re: Going to the drag strip tomorrow, tire pressure question. (Reid)
I get my best 60' at 18psi... but then again that's on kumhos
BTW what did you run?
