help me out, want to bore out B18C1
Old Jul 1, 2003 | 10:49 PM
EKweezy's Avatar
Default help me out, want to bore out B18C1
this might not be the forum to post but more ppl speak out here,
ok, i bought a B18C1 with a resleeved Golden Eagle sleeves, the block spun a rod bearing.
i want to bore it out to a minimum of 84 mm or 84.5mm, or a max of 85mm or 85.5mm, whatever best setup you guys think? give me your opinions.
i researched and found it can get a minimum of 1932cc from 84mm bore and a max of 2002cc from 85.5mm bore.
now by boring the cylinder out will it change the rod/stoke ratio?
ok, now what else need to be done so i can get a closest of a 2.0L?
Old Jul 4, 2003 | 10:36 AM
TurboTeG4's Avatar
Default Re: help me out, want to bore out B18C1 (EAZY)
Hope you dont mind me adding to your post,its on same topic. Im also doin a b18c1 buildup and bought ross pistons over bore .5 My uncle came over today and he builds domestic race cars and told me I dont know what im goin that I should bore my engine a lot bigger with bigger pistons. This is for a t3/t4oe 57 trim, .63a/r exhaust housing, with a stage 3 blade setup and I already bought stock lenght eagle rods. Should I just go with what I originally planned or go with bigger pistons and how big??Will it work with my rods, im also plan to use darton sleeves
Old Jul 4, 2003 | 10:47 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: help me out, want to bore out B18C1 (turbocivic4)
do what we did on the ITR build up I did for my room mate.
Darton solid deck 83mm sleeves, bored to 84.5. Now we have 1997 cc displacement in the B20C5
It will not effect your rod stroke ratio either by going oversized
bulletproof bottom end
Old Jul 4, 2003 | 10:59 AM
92 civic VX B18c's Avatar
HT Black Ops
Default Re: help me out, want to bore out B18C1 (Emerika)
Did you rebuild that engine in your living room?
Old Jul 4, 2003 | 11:00 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: help me out, want to bore out B18C1 (92 civic VX B18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 civic VX B18c &raquo;</TD></TR><TR><TD CLASS="quote">Did you rebuild that engine in your living room?</TD></TR></TABLE>
yeah. I built it in my living room...best place to do it
Room temp, get more accurate clearances.
Oh, and I could "spend time with the girlfriend" at the same time...cause she hates the garage...lol.
Old Jul 4, 2003 | 11:01 AM
Doeboy's Avatar
nice couch, is that jdm??? haha
Old Jul 4, 2003 | 11:07 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: (onefastcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onefastcivic &raquo;</TD></TR><TR><TD CLASS="quote">nice couch, is that jdm??? haha
no, it's a clean couch
Old Jul 4, 2003 | 11:59 AM
TurboTeG4's Avatar
Default Re: (Emerika)
Will the oversized pistons be much better for the turbo, which im sure it would be?
Old Jul 4, 2003 | 12:02 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (turbocivic4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbocivic4 &raquo;</TD></TR><TR><TD CLASS="quote">Will the oversized pistons be much better for the turbo, which im sure it would be?</TD></TR></TABLE>
bigger displacement= more torque, less turbo lag, and quicker spool.
Old Jul 4, 2003 | 01:56 PM
976's Avatar
976
New User
Wowwee Evan, looks dope.
Old Jul 4, 2003 | 10:30 PM
TurboTeG4's Avatar
So should i re-sell my ross pistons which is .5 overbore for bigger pistons cause i plan on resleeving. How much overbore should i go for the turbo??
Old Jul 4, 2003 | 10:41 PM
Evs-One's Avatar
Solbros Owns Me
this is a D16Z6, correct??? I would just resleeve and go .5 over. That is the most you can safely go without going with a solid deck sleeve kit
With the built bottom end, and upping the boost will deffinately be nice.
Old Jul 5, 2003 | 12:03 AM
TurboTeG4's Avatar
No this is a b18c1 build up with darton sleeves
Old Jul 5, 2003 | 12:12 AM
built562's Avatar
how big a bore can you go before you have head gasket sealing problems? which head gasket do you use for a 84mm b18c1.
Old Jul 5, 2003 | 05:17 AM
VWkila's Avatar
Default Re: help me out, want to bore out B18C1 (akumaracer)
How much would a darton sleeve cost me in total?
Old Jul 5, 2003 | 05:26 AM
Nikos's Avatar
Default Re: help me out, want to bore out B18C1 (VWkila)
buy the sleeves shouldn't be varey expensive.... i think $400....
Finding a shop to install them is another story....
Old Jul 5, 2003 | 06:20 AM
boostedgsrcivc's Avatar
i would go 84mm. that's what i'm doing on my b18c1. i've talked to many builders and they all agree that's the way to go. i'm using wiseco pistons, but if you're intrested i got some JE 84mm pistons low comp. pistons i can sell you for cheap. just email me.
Old Jul 5, 2003 | 08:25 AM
Evs-One's Avatar
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VWkila &raquo;</TD></TR><TR><TD CLASS="quote">How much would a darton sleeve cost me in total?</TD></TR></TABLE>
depends. Just sleeve inserts, my brothers shop charges 600 installed with prep work and bore/hone to desired size.
The picture above, which is the solid deck kit, was 1200 installed with prep work and bored/honed to size
If you question the difference between 1.8 and 2.0 liters....check this.
The Type R pulls harder now with 8 psi boost and 9.8:1 compression with the 84.5 mm bore, than it did with the stock bottom end and 10.8:1 compression.
The difference is rediculous, I can't wait to drive this thing at 18 psi on the love fab manifold and SC61 turbo
Old Jul 5, 2003 | 04:53 PM
VWkila's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">
Last year, I had Golden EAgle sleeve and hone my B18 for $900, I beleive, plus $150 for S&H.
I now have a B16 I want to work on. Do you recommend GE or Darton. I plan to go NA.
byrne_06
Feb 7, 2011 04:43 PM
tspkenneth
Jan 7, 2005 03:46 PM
ptsaurus
Mar 20, 2004 05:33 PM
SleeperNine
Jun 18, 2003 10:18 AM
Mr. Softee
Feb 26, 2002 11:15 PM
