what causes this to happen???
Is it disconnecting from the plug or just backing out a little...
If the lead wire goes down too far from the cap it'll sit that high.. I got taylor wires and they ALL sit too high like that...
If it's popping off the plug the only thing I could think of would be the plug is loose enough that the cylinder is pumping air past it and blowing off the wire...
good luck
good luck
mine did that when I was pinging running 13.5:1 compression. Went back to stock, wires didn't move.
Used the same MSD wires both times...it makes a loud tick noise right when it happens also
tried to use pliers to tighten the "clip" but cant get in far enough and the plugwire connects to the plug I can feel it...and I guess I'll have to see if I have to tighten the plugs more
Well, it could be caused my excessive crank case pressure. I too have been having this problem lately and I can actuall hear the wire pop off sometimes. I tried out Endyn's way of evacuating crankcase pressure (www.theoldone.com - check out their B20 article for their technique) and so far it seems to be working out for me
JDM_SOHC
Apr 30, 2007 02:24 PM
