OBD 1 Distributor needed
I just put a B16A in my girls 94 ex coupe and the new motor needs a distributor. The fron tbearing in it is destroyed and you can move the rotor about an inch side to side. LoL - makes a horrible noise. I need one pretty bad so lemme know what will work. I was thinking maybe one from a 94 GSR? please help. I am also selling her old EX motor. it is a d16z i think SOHC vtec with 74kmi on it. Comes with tranny and ecm if i still ahve the ecm. Let me know.
Thanks,
Wayne.
Thanks,
Wayne.
you can actually reuse every part of yr ex distributor onto a b-series distributor, except for the housing.... and the input shaft.. Those two things are only things that differ between the two, but since you said the front bearing.. sounds like the input shaft... so i guess you're outta luck..
to Smooch Pickle
