Engine rebuild questions
Alright i have been dealing with b series motors for the most part and i just got back into d series.
Well the deal is, i have a z6 that im gonna rebuild. But i want to change the pistons to add some compression. I was using the d series calculator to calculate the ratios. And the dx pistons (pm3) raise it to 11.2:1. Or so it says. how accurate is that?
Also what pistons do you guys recomend and which would fit? Any help at all would be appreciated.
i am pretty sure the DX pistons will fit. if they have the same diamete as the z6 pistons, then they will.
i say go for it. if you want some really high comp, get some 88-89 teg pistons.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keithv »</TD></TR><TR><TD CLASS="quote">i am pretty sure the DX pistons will fit. if they have the same diamete as the z6 pistons, then they will.
i say go for it. if you want some really high comp, get some 88-89 teg pistons .</TD></TR></TABLE>
You should try DOHC ZC pistons Ive heard they raise the compression to 12.1 and after using that knology calculator it might be true. I might try it on my z6 soon.
yeah i was thinking about the zc pistons ...but according to the calculator it raises the compression like 13:1 thats kinda high i think...i want to run pump gas for the most part so i thought that 11.2:1 would be good. But i just dont know how accurate it is. And if there is anything i have to do to make them fit properly
hatchinprogress
Nov 14, 2005 05:33 PM
