A LIL pistion info.....STICKY LIKE HONEY
Piston-to-Cylinder Wall Clearance
Bore Diameter Naturally Aspirated Forced Induction
75.50 mm 0.0021" 0.0022"
81.50 mm 0.0026" 0.0027-0.0028"
84.50 mm 0.0027" 0.0028-0.0029"
87.00 mm 0.0030" 0.0031-0.0032"
The cylinder walls should be finish honed with a 380 Grit stone to give a 60' crosshatch pattern as per Honda's specifications.
Piston Ring End Gap
Bore Diameter Naturally Aspirated & Forced Induction
75.50 mm 0.011"
81.50 mm 0.011-.012"
84.50 mm 0.012-0.013"
87.00 mm 0.014-0.015"
Piston-to-Cylinder Head Clearance
With Eagle Steel Connecting Rods: 0.035" Minimum
With Factory Connecting Rods: 0.045" Minimum
Valve-to-Piston Clearance
Intake Valves: 0.045" Minimum
Exhaust Valves: 0.060" Minimum
Engine Break-In (1,000 Miles)
Use a Honda engine oil filter ONLY!!!
Use a 30W, non-detergent, non-synthetic engine oil ONLY!!!
DO NOT take the engine over 3,500 RPM during the first 200 miles of operation. You can increase the maximum engine speed by 500 RPM for every additional 200 miles of operation.
DO NOT operate the engine in a "steady state" mode (no open-road driving).
Change the oil and filter after 1,000 miles of operation. Synthetic or non-synthetic engine oil can be used. We use, and recommend Mobil 1.
Use Honda engine oil filters ONLY!!!
Piston Ring End Gap
75.50 mm 0.011"
I JUST THREW THIS IN THERE http://www.theoldone.com/artic..._tips/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzSi22 »</TD></TR><TR><TD CLASS="quote">Your piston/wall clearance should be according to the manufacturer specs... Each one is different really... So is the ring gap...</TD></TR></TABLE>
This is true. Check with the manufacturer first.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wm5holla »</TD></TR><TR><TD CLASS="quote"> Piston-to-Cylinder Wall Clearance
Are these clearances for naturally aspirated or forced induction? For cast pistons or forged? Stock or aftermarket? They shouldn't all be the same, should they?
The numbers are from Endyne, they are for forged pistons. Stock pistons run much tighter piston/cylinder clearance (.0006-.0014). I think they are closer to NA specs, Turbo specs are usually a bit looser
VtecKiDD
46
May 5, 2008 06:39 AM
cioli
May 5, 2007 04:26 AM
