Will a D16A8 header fit a D16A6?
Old Jul 1, 2003 | 04:05 PM
SPORT INJECTION's Avatar
Default D-Series header question....
Lets just say I found a used DC header cheap. I havent heard back from him yet on the year civic it was on. The guy says it WILL fit any D series. Is this possible?
Old Jul 1, 2003 | 04:09 PM
EL Vap133's Avatar
Default Re: D-Series header question.... (SPORT INJECTION)
I think it will possibly bolt up to the block, but the length of the downpipe is what's different I believe...
Old Jul 1, 2003 | 04:20 PM
CimorelliCRX's Avatar
Default Re: D-Series header question.... (Vap133)
IT will bolt to the head, and it should be fine, and if its cheape nough just pick it up, and get the flange rewelded for like 15 bucks. I used a 92-95 chikara and it was fine, the flange was just flipped the wrong way so i had to get it rewelded, or something like that. Actually they were perfect, what was wrong was the exhaust place eliminated that middle pipe between the down pipe and the cat, and i had to get it moved back. Go for it, if not let me know, I will get it,
Old Jul 1, 2003 | 07:36 PM
finally got a reply.....Turns out it was on a 88 CRX Si w/ D16a8...sounds like it will work heh?
Old Jul 1, 2003 | 08:18 PM
silverpenny's Avatar
yes it will
Old Jul 2, 2003 | 05:43 AM
Default Re: D-Series header question.... (silverpenny)
I guess a D16A8 is a dohc ZC from the UK
Old Jul 2, 2003 | 07:37 AM
DJ_SaNdOz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPORT INJECTION &raquo;</TD></TR><TR><TD CLASS="quote">I guess a D16A8 is a dohc ZC from the UK</TD></TR></TABLE>
yup
Old Jul 2, 2003 | 10:38 AM
Default Re: D-Series header question.... (DJ_SaNdOz)
well I won the auction ...so hopefully it will work.
http://cgi.ebay.com/ebaymotors...84261
Old Jul 2, 2003 | 11:23 AM
91civicDXdude's Avatar
I used a 92-95 header on my z6 swap in my 91, it bolted right up. I would think that since pretty much all honda exhaust are the same length, it will work. on my b18a1 swap however, i had to get the exhaust shortened a bit, the header was about 3 inches too long, but all d series are the same.
Old Jul 16, 2003 | 05:06 AM
Default Re: (91civicDXdude)
turns out it fits the head but doesn't line up to the cat. Time for the old cut and turn trick. Still a good deal for a DC SS header... $137
Old Jul 16, 2003 | 06:32 AM
DJ_SaNdOz's Avatar
Default Re: (SPORT INJECTION)
Is it the flange that doesn't fit? I'm just curious b/c I am trying to find either a header for the UK ZC or for the 89 teg & I am wondering if I'll have the same issue.
Old Jul 16, 2003 | 07:53 AM
philly-O's Avatar
Default Re: (DJ_SaNdOz)
i just bought a used 4-1 dc header from a buddy who had it on his 96. i also bought a 92-00 cat, so hopefully if helps with the lining up part. i will let you know how it fits hopefully later today.
Old Jul 16, 2003 | 08:16 AM
cui's Avatar
cui
if you can get a hold of the 90~93 integra cat...then you don't have to do the turn-n-weld trick....
Old Jul 16, 2003 | 10:57 AM
Default Re: D-Series header question.... (cui)
i just had the downpipe flange turned and re-welded and overlapped .5" so it will fit dead nuts. Only $10 on my lunch break...
Old Jul 16, 2003 | 06:44 PM
philly-O's Avatar
where did you go to have it rewelded? i put mine on tonight and it was sooooo close that we used the bolts to align it. there is only a small exhaust leak under the car (probably from using the old exhaust doughnut)
Old Jul 16, 2003 | 08:05 PM
Default Re: D-Series header question.... (peichie)
mufflers for less.............but **** man.... I gotta go back there again. Lines up good but some how its still tooo long. ****** crap....i dont get it
Old Jul 16, 2003 | 08:06 PM
well.............im flying to NYC tommorrow for a few days soo who cares...
**** cars for now
Old Jul 16, 2003 | 09:28 PM
Steve91's Avatar
I had a DC 4-1 header from a Y8 on by A6 CRX. It fits fine, but I have a place racing cross member so that makes the installation real easy. You will have to have your exhaust slightly modified to line it up with the header, but its really easy.
I'm selling a DC4-1 if your interested.
Old Jul 17, 2003 | 05:44 PM
philly-O's Avatar
Default Re: D-Series header question.... (Steve91)
yeah..that "small" leak is loud and annoying now. i promptly need to get it fixed.
Old Jul 23, 2003 | 08:24 PM
Header is officially on.
I had to have another inch taken off.
-Dave
Old Jul 23, 2003 | 08:39 PM
MrTodd's Avatar
That's wierd.
(look at my setup below in my sig, z6 block, y8 head, '90 crx si)
I've had a 88-91 Chikara header installed on my current motor with no probs, the downpipe bracket (that bolts to the block) didn't fit exactly, so I just left it without that hangar, no problems at all.
I now had a DC 4-2-1 header for a 96-00 Civic Ex installed, it bolted up perfectly, downpipe hangar fits now, and the downpipe fits the catylytic converter just fine (bolt-in Catco).
So in other words, any D-series header, from 88-00 should be interchangeable with no modification. The only thing that will vary is the downpipe hangar that attaches to the block. I don't know why you guys have to do all this welding... The length of the downpipe should be the same for all years.
Old Jul 23, 2003 | 11:04 PM
philly-O's Avatar
Default Re: D-Series header question.... (MrTodd)
what is different is the bolt location on my car from the header to the cat. it is really close, i used a test pipe and problem is solved. the only thing is now the car is loud as hell and i have no backpressure, so low rpm city driving is interesting.
Old Jul 24, 2003 | 04:45 AM
Headers are soo overated. I feel a little more response in mid and it feels better up top..
Old Jul 24, 2003 | 06:25 AM
FR-MOB: ThE bEe GuY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPORT INJECTION &raquo;</TD></TR><TR><TD CLASS="quote">Headers are soo overated. I feel a little more response in mid and it feels better up top..
What are your mods? With basic mods (intake, header, exhaust) its not really going to make a Big difference, but later on when you get other crap done like porting, cam, stuff like that, it'll help. When i put my DC 4-2-1 ceramic on my A6 i did notice a big difference with only intake and a muffler. The pull from 4k and up hit a lot harder, the bottom end had a tad bit more power, but the pull from 4K up...woo hoo BTW, my dumbass didnt take off the downpipe bracket that bolts onto the block, so now theres a dent in one of the header pipes because of the bracket rubbing on it
Old Jul 24, 2003 | 06:29 AM
Default Re: D-Series header question.... (ThE bEe GuY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThE bEe GuY &raquo;</TD></TR><TR><TD CLASS="quote"> The pull from 4k and up hit a lot harder, the bottom end had a tad bit more power, but the pull from 4K up...woo hoo </TD></TR></TABLE>
exactly! Im sure when and if I ever build up a D it will pay off.
Right now I have AEM CAI, dc 4-2-1, 2.25" from cat back with magnaflow
