Who makes a good rear camber kit?
Old Jul 1, 2003 | 03:24 PM
Bill Hook's Avatar
Default Who makes a good rear camber kit?
I've done some looking but would like to hear some pros and cons, as well as prices and sources.
FWIW, I have around -1.1 and -0.7 degrees (within spec) at left and right, respectively.
I have ITR springs and KYB AGX struts on a '01 G3 'teg.
I'd like to be able to get these figures closer to parity and a little less negative.
Old Jul 1, 2003 | 03:29 PM
andrew dc's Avatar
Default Re: Who makes a good rear camber kit? (Bill Hook)
i really think the washer trick works the best.. maybe like $.50..... that is what most rear camber kits are anyway!
Old Jul 1, 2003 | 04:05 PM
Spoodge's Avatar
From: Slut City aka San Diego, Ca, United State Of King
front i would go with skunk2 camber kit and for the rear use washers... skunks 2 comes with a arms.. they work better than ingalls
Old Jul 2, 2003 | 08:15 AM
Bill Hook's Avatar
Default Re: (SpoodgeDc2)
Problem w/ washers is that it would sure be damned hard to fine tune them, particularly when you'd have to keep paying the alignment guy to bolt and unbolt everything and stick washers in. It's also a judgement call on how thick they ought to be, as most of what I've read says that each washer is good for a degree; again, this depends on thickness.
I think I need a rear kit to get the adjustments right, considering where my numbers are already.
I've heard a little about Ingalls kits, but not all of it good.
I'm looking for durable and cheap; the best quality product for the least money. Nothing made of white metal, but neither do I want to pay $400 b/c it has "SPOON" emblazoned across it. It just has to allow a couple degrees of adjustment.
Thanks.
Old Jul 2, 2003 | 08:24 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (Bill Hook)
I would leave it where it is. You don't want straight up 0 camber, the car will handle poorly compared to if you leave it with some negative camber. If you're worried about tire wear, don't. Just get the toe set correctly and rotate the tires often and you'll be straight. My car is running -2.3 in front and -2 in back for camber and I've had no problems after 35K miles.
Old Jul 2, 2003 | 08:31 AM
PM-Performance's Avatar
Default Re: (PatrickGSR94)
I have a few sets of SPC's, they cost a little more , but from the people that have ignalls and seen mine swapped out shortly after, they are alot sturdier, and easier to adjust , i have rear upper controll arms and lower anadized control arms which save qwuite a bit of weght and have the nice bling factor. ill post up pics when i get time. I just did a set on my EP this weekend .
Old Jul 2, 2003 | 09:57 AM
Bill Hook's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">I would leave it where it is. You don't want straight up 0 camber, the car will handle poorly compared to if you leave it with some negative camber. If you're worried about tire wear, don't. Just get the toe set correctly and rotate the tires often and you'll be straight. My car is running -2.3 in front and -2 in back for camber and I've had no problems after 35K miles.</TD></TR></TABLE>
It just bothers me that the numbers are half a degree apart from side to side.
My fronts are -1.1 and -1.2, which is good enough.
I'd like to dial back the negative rear camber to around -0.5 each side.
Old Jul 2, 2003 | 09:58 AM
Bill Hook's Avatar
Default Re: (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">I have a few sets of SPC's, they cost a little more , but from the people that have ignalls and seen mine swapped out shortly after, they are alot sturdier, and easier to adjust , i have rear upper controll arms and lower anadized control arms which save qwuite a bit of weght and have the nice bling factor. ill post up pics when i get time. I just did a set on my EP this weekend .</TD></TR></TABLE>
Thanks.
Bling definitely not a factor in any decision I'm making.
Old Jul 2, 2003 | 10:03 AM
im saying for the LCA's, the erst of the stuff is straight forward desighns , and well built, not like some of the toher stuff ive seen , , wont mention any names.
Old Jul 2, 2003 | 10:06 AM
ExospeedAMcrx's Avatar
After using the SRR and the SPC rear camber and toe kits from both companies, I wouldnt even go the Washer way anymore. the adjustable ones from SRR and SPC are way better and easier to adjust.
Old Jul 2, 2003 | 10:13 AM
Aaron M's Avatar
im running the home depot spec kit
Old Jul 2, 2003 | 10:20 AM
Default Re: (exospeedAMcrx)
yea i adjusted the ones on the ep in like 30 sec for both sides. it dont get easier thna that .
Charlie Moua
Jun 13, 2014 02:12 PM
K20Death
Honda Civic (2006 - 2015)
10
Oct 13, 2006 11:36 AM
KArowd
May 1, 2006 06:33 PM
Edwin
May 13, 2003 11:31 AM
