How dependable is a b20 Vtec (b18c head) for Daily Driving Please!!!
Well i blew up the gsr... so now i need something else.. asap
I can get a fairly new b20 motor.. and i have found some gsr heads...
What all is involved with this motor...
will it make more power then if i had a b18c1 block?
what pistons can i run.. will stock work for now?
any info would be greatly appreciated.. i want to get the parts by thursday and be on the road by sunday
THanks
CHris
THanks
CHris
your sig makes me vomit
anyway, you want to ditch the b20 pistons, and get some b16/type r / other pistons, and basically, you can do it, its the exact same as an ls/vtec. you should start reading now. check the link in my sig, learn about what you gotta do, and search for b20vtec
http://www.b20vtec.com
http://www.c-speedracing.com
and if you do it right i have heard people's lasting from 40K to 80K, depends on how you build it, maintain it, and how you treat it.
BTW, what did you "blow up" in your GSR? spun rod bering? misshifted? what?
I know where you can get a completely built b20 bottom for 2200
it will last to. Fresh bearings, endyne 12:1 pistons, eagle H rods, knife edges crank and aluminum pulley. All that you need to do is pick up a dash 4 oil line I believe and tap your stock GSR head. Depending on what you blew you should be able to still use the GSR head from your old motor. Well I am just assuming because most the time the crank or rod bearings are what go... as far as relaibility before this motor was built it was ran daily on the street and did nothing but whip ***!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skribblah »</TD></TR><TR><TD CLASS="quote">
I thought the b20 block was an 84mm bore and the other b series blocks were 81mm bores?
well one of the pistons was the size of the golf ball, cracked a sleeve, head is trashed.. big hole in the block too.. dont quite know what happened.. we were testing and tuning my new parts..
not sure how the rods were
Chris
just found a head..
now i need a block.. dont know b18c or b20
Chris
just found a head..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverDC4 »</TD></TR><TR><TD CLASS="quote">
I thought the b20 block was an 84mm bore and the other b series blocks were 81mm bores?</TD></TR></TABLE>
whops i was thinkin of ls/vtec! hehe my B
