Those of you with JUN 3s, where do you have VTEC engage?
Old Jul 1, 2003 | 02:41 PM
RTW DC2R's Avatar
Default Those of you with JUN 3s, where do you have VTEC engage?
PM me if you dont want anyone to know you have JUN 3s
I currently have VTEC engage at 6200. Im using the AEM EMS ecu, and I can set VTEC to engage at a certain throttle%. So basically what I can do is control VTEC engagement with my foot, depending how much throttle I give it. Ive played around with it some, and it seems by my butt dyno that revving past the VTEC point without engaging VTEC, the low cam on the JUN 3s pulls extremely hard, seemingly harder than when VTEC engages on the bigger lobe. So Im really curious to know if anyone with the JUN 3s has VTEC set higher than I do. I would try to test my theory on my own by raising VTEC, but I dont have a wideband to tune the fuel if I moved VTEC any higher. Just curious.
Old Jul 1, 2003 | 02:45 PM
GZR4DR's Avatar
Default Re: Those of you with JUN 3s, where do you have VTEC engage? (RTW DC2)
When I had them, at 6K rpm's. On the dyno this spot had the best powerband. Graph was smooth and you could hardly even tell where vtec engaged.
Old Jul 1, 2003 | 02:51 PM
Chubz's Avatar
Default Re: Those of you with JUN 3s, where do you have VTEC engage? (GZR4DR)
mine was at around 6800 rpms, i used a pretuned SGT JUN III map and made 209/139 to the wheels
Old Jul 1, 2003 | 02:58 PM
RTW DC2R's Avatar
Default Re: Those of you with JUN 3s, where do you have VTEC engage? (B18CR01)
OK cool. Im also kind of wondering if this means my motor might like smaller cams?? It currently makes and holds power all the way to 9500 so I know it likes top end but Im just curious if maybe this is an indication that it might like a smaller cam as well. Just playing with some ideas.
Old Jul 1, 2003 | 06:09 PM
canuck-mx6's Avatar
damn, mines set at 5700, makes peak power at 9000, holds the power all the way to 9300 where my rev limit is.
Old Jul 1, 2003 | 06:15 PM
98itR484's Avatar
Default Re: Those of you with JUN 3s, where do you have VTEC engage? (canuck-mx6)
5900.
Old Jul 1, 2003 | 06:51 PM
IN VTEC's Avatar
On my friend's car it crosses around 5500rpm.
JUN 3's with JUN pistons and JUN ECU.
No changes b/w the runs. Lots of variation b/w runs.
Old Jul 1, 2003 | 07:01 PM
JDM CTR '00's Avatar
Default Re: Those of you with JUN 3s, where do you have VTEC engage? (PacMan ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PacMan ITR &raquo;</TD></TR><TR><TD CLASS="quote">5900. </TD></TR></TABLE>
Old Jul 1, 2003 | 07:08 PM
RTW DC2R's Avatar
Default Re: Those of you with JUN 3s, where do you have VTEC engage? (ChargedSi99)
that chart reminds me a lot of how my car feels sometimes. very inconsistent. sometimes if feels like it pulls hard as hell, other times its like ummm where did the power go. I also need a valve adjustment so that might part of the problem. Im gonna do some experimenting tomorrow with my throttle% and see how hard the low cam pulls and for how long. You think I can damage the motor by doing this? I can basically set it so that VTEC doesnt engage at all and rev it to redline but I wont do it if it might cause a problem or damage something.
Old Jul 2, 2003 | 04:26 AM
sgT's Avatar
sgT
4500-5500 Usually.
Old Jul 2, 2003 | 05:43 AM
canuck-mx6's Avatar
Why so many different VTEC X-over points for what is essentially the same setup?
Old Jul 2, 2003 | 05:46 AM
sgT's Avatar
sgT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by canuck-mx6 &raquo;</TD></TR><TR><TD CLASS="quote">Why so many different VTEC X-over points for what is essentially the same setup?</TD></TR></TABLE>
How do you figure they are essentially the same? The only similarity i see here is
the cams.
Old Jul 2, 2003 | 05:48 AM
RTW DC2R's Avatar
OK, to further add to this JUN 3 thread, what are your cam gears set at? We have messed around with mine a little on the dyno, but it seems the cams like to be set at 0 degrees for both intake and exhaust cam. Anyone else find that they dont like to be too far from 0? My tuner says that usually you dont have to do too much cam gear tuning with the JUN 3s and they typically like it around 0, 0.
sgT's Avatar
sgT
never had a set stay at 0.
Old Jul 2, 2003 | 05:55 AM
RTW DC2R's Avatar
Default Re: Those of you with JUN 3s, where do you have VTEC engage? (sgT)
steve, whats the max (advanced or retarded) you've seen the JUN 3s set at?
Old Jul 2, 2003 | 06:00 AM
sgT's Avatar
sgT
most ive ever had to go is 6 degrees.
Old Jul 2, 2003 | 04:40 PM
alexboy's Avatar
JUN ECU for SALE ...... just thought i would add that ... I.M. me
Old Jul 3, 2003 | 05:54 PM
HaUTSaauce's Avatar
New User
Default Re: Those of you with JUN 3s, where do you have VTEC engage? (alexboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexboy &raquo;</TD></TR><TR><TD CLASS="quote">JUN ECU for SALE ...... just thought i would add that ... I.M. me</TD></TR></TABLE>
i want it
Old Jul 3, 2003 | 11:07 PM
JDMb18civic's Avatar
Old Jul 4, 2003 | 11:04 AM
gary201147's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">that chart reminds me a lot of how my car feels sometimes. very inconsistent. sometimes if feels like it pulls hard as hell, other times its like ummm where did the power go. I also need a valve adjustment so that might part of the problem. Im gonna do some experimenting tomorrow with my throttle% and see how hard the low cam pulls and for how long. You think I can damage the motor by doing this? I can basically set it so that VTEC doesnt engage at all and rev it to redline but I wont do it if it might cause a problem or damage something. </TD></TR></TABLE>
I doubt you will have any damage running only the primaries all the way to the redline. The only reason for not doing so is because power will drop off much earlier in the powerband than if you were to engage VTEC.
Old Jul 28, 2003 | 04:07 AM
advanracing62's Avatar
Default Re: Those of you with JUN 3s, where do you have VTEC engage? (gary201147)
56250 to be exact
Old Jul 28, 2003 | 04:39 AM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: Those of you with JUN 3s, where do you have VTEC engage? (advanracing62)
Wait a minute...56250? 56,000 rpm? This was useless, we all know what you meant, but I just had to.
b16master
Oct 17, 2009 09:42 PM
mdj_ge
Jun 29, 2005 09:28 PM
xvracing
May 1, 2004 01:49 PM
gsrallday
Nov 7, 2003 12:14 PM
