will d series starter fit b series
Old Jul 1, 2003 | 09:06 AM
DubyaAye's Avatar
Default will d series starter fit b series
will d series starter fit b series. the starter on my b series is about to go and i was wondering will the d series one work?
Old Aug 29, 2003 | 08:04 AM
tunedbylorange.com's Avatar
Default Re: will d series starter fit b series (DubyaAye)
just make sure you buy a starter for whatever tranny your using, not the motor
for example if you have a VTEC motor and you have an LS (non-VTEC) tranny make sure you buy the starter for the LS tranny, not the VTEC motor...because different transmissions take different starters
Old Aug 31, 2003 | 07:39 PM
darrinbrewer's Avatar
Default Re: will d series starter fit b series (tunedbylorange.com)
wouldn't it depend on what flywheel you were using? because the starter turns it right?and all b series tranny's work with all b series motors..so do you use the flywheel for the motor..or the flywheel for the tranny...for example a ls with a gsr tranny...would you use gsr flywheel..or a ls flywheel??
Old Aug 31, 2003 | 08:12 PM
xteg95's Avatar
Default Re: will d series starter fit b series (darrinbrewer)
i thought all b-series starters were the same...i could be wrong, anyway i dont think the d series start will work on a b series motor, but i believe the b series starters work on a d series motor.
OBDII Integra
Apr 29, 2011 03:11 PM
dasickestda9
Jun 17, 2007 08:20 PM
chuy_ads
Sep 29, 2004 10:18 AM
Jdmbsixteen
Sep 2, 2003 09:45 PM
