b18c1 block with b16 head VS b18c1 block with b18c1 head
Old Jul 1, 2003 | 09:05 AM
Nikos's Avatar
Default b18c1 block with b16 head VS b18c1 block with b18c1 head
Looking for a head to match the b18c1 block.
Please enlighten me. What kind of numbers should I expect out of these 2 setups? Assume CTR or ITR pistons/rods and everything else stock.
A complete b16 head is significantly cheaper so I need to know the truth.
Thanks
Old Jul 1, 2003 | 09:20 AM
white99gsr's Avatar
Default Re: b18c1 block with b16 head VS b18c1 block with b18c1 head (2 B 4GO10)
what are your goals??? FI or NA??
FI=GSR
NA=B16
Old Jul 1, 2003 | 09:25 AM
Nikos's Avatar
Default Re: b18c1 block with b16 head VS b18c1 block with b18c1 head (white99gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white99gsr &raquo;</TD></TR><TR><TD CLASS="quote">what are your goals??? FI or NA??
FI=GSR
NA=B16
NA for sure.. I cannot afford boost.
Old Jul 1, 2003 | 09:33 AM
xJ.SLOTHx's Avatar
be a little more specific in what your buildup will consist of and it will be easier to answer your questions. you might wanna check out the all motor forum as well for similar threads like yours.
Old Jul 1, 2003 | 09:39 AM
976's Avatar
976
New User
Default Re: b18c1 block with b16 head VS b18c1 block with b18c1 head (ian)
B18C block w/ B16A head - high TQ/ good HP
B16A block w/ B18C head - high HP/ low TQ
Which is very vage, however gives a good idea of the top different setups.
Old Jul 1, 2003 | 10:05 AM
Nikos's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ian &raquo;</TD></TR><TR><TD CLASS="quote">be a little more specific in what your buildup will consist of and it will be easier to answer your questions. you might wanna check out the all motor forum as well for similar threads like yours.</TD></TR></TABLE>
Ok, the block will have ctr pistons and rods. It will be blasted/acid cleaned, balanced and the crank will get polished/turned.
The 2 heads I am considering will be stock.
Old Jul 5, 2003 | 09:45 AM
HaUTSaauce's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2 B 4GO10 &raquo;</TD></TR><TR><TD CLASS="quote">
The 2 heads I am considering will be stock.</TD></TR></TABLE>
if your goal is NA then i would go wit the b16 head
just my .02 cause i currntly have that setup and it seems faster than my stock gsr
Old Jul 5, 2003 | 10:53 AM
built562's Avatar
Default Re: b18c1 block with b16 head VS b18c1 block with b18c1 head (HaUTSaauce)
go with the gsr head, it will give a slightly higher compression ratio or just get the chambers welded on a b16 head.
there have been many debates on which flows better, i feel the b16 flows better and its cheaper
Old Jul 5, 2003 | 11:39 AM
JV's Avatar
JV
Who?
Default Re: b18c1 block with b16 head VS b18c1 block with b18c1 head (akumaracer)
They flow virtually the same:
It's really the cam and IM design, that become the deciding factors between the 2 stock heads IMO...
The GSR head will up the compression slightly. Here's why:
Pics courtesy of Katman
Just some tidbits for ya. Good luck...
Edit: Found this too. Search function rules...
B16 vs GSR
Modified by JV at 4:27 PM 7/5/2003
Old Jul 5, 2003 | 11:46 AM
SpoonFedHatch's Avatar
Default Re: b18c1 block with b16 head VS b18c1 block with b18c1 head (JV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JV &raquo;</TD></TR><TR><TD CLASS="quote">They flow virtually the same:
Good luck...
very informative pics/graphs
Old Jul 5, 2003 | 02:08 PM
GradyDC5's Avatar
I've got a b18c1 now but i'm debating on putting a b18a bottom end with pr3 pistons with my gsr head. Oh get the gsr head .
Old Jul 5, 2003 | 02:44 PM
DOHCtorTHRUST's Avatar
Default Re: (ReallySlowEg)
you will get a slightly higher compression on the gsr head( as if they were both stock) but with me, i went with b16 head because i didnt want to shell out 3 bills for a skunk IM for the gsr head(i hate the design on the gsr IM)... with the b16a i can use ITR IM
my CTR pistons will compensate for the lost in compression for not using the gsr head....
i hope you will get a better idea with all the info given above...
da4sale
Jun 5, 2007 12:02 AM
B18Sleeper
Oct 2, 2005 12:01 PM
P_t0wn
May 1, 2005 08:32 PM
99simass
Sep 9, 2001 09:30 AM
