Tools needed for engine build?
Old Jul 1, 2003 | 08:06 AM
Witty's Avatar
Default Tools needed for engine build?
I know nothing about building engines and I don't pretend too. I plan on buying a bare block and start building it from the ground up just to learn. How much do you guys expect I'm going to end up spending on specialty tools? I have your basic tool kit and an air compressor but that is about it. Just trying to get an idea of what I'm getting myself into.
Old Jul 1, 2003 | 08:18 AM
b19coupe's Avatar
Default Re: Tools needed for engine build? (Witty)
You will need a couple of torque wrenches and a piston ring compressor, as well as piston ring pliers. A Helms or Honda service manual are also indispensable.
Old Jul 1, 2003 | 08:23 AM
F1Spec's Avatar
Default Re: Tools needed for engine build? (b19coupe)
you need a lot more than that. lots of special tools than just wreches & sockets.
Old Jul 1, 2003 | 09:03 AM
ArinX's Avatar
torque wrench! cant build a motor without a good accurate one. Helms manual. And some other specialty tools ie valve adjustment, the ring compressor as well as some measuring tools for the bearings.
Old Jul 2, 2003 | 05:15 PM
civicsitek GanGsTa's Avatar
Default Re: Tools needed for engine build? (ArinX)
torque wrench
allen wrench set
feeler gauge
micrometer (not the slide kind)
full metric socket set
valve spring compressor
u can adjust the valves with a 10mm wrench and small flathead and check with the feeler gauge
that's about it besides lube and machining tools
Old Jul 2, 2003 | 08:59 PM
3rdGteg's Avatar
Default Re: Tools needed for engine build? (civicsitek)
don't forget a set of inside mic, or bore gage to measure for out-of-roundness and taper in the cylinders.....plus all the tools they've listed above.
Old Jul 2, 2003 | 09:42 PM
Tbone's Avatar
Check this out
https://honda-tech.com/zero...35624
le0ftw
Jun 8, 2007 11:32 AM
Leo.
Dec 12, 2006 08:13 AM
98vtec
22
Oct 19, 2006 10:10 AM
1JDMDOMINICAN
Apr 15, 2006 05:32 AM
