Parts list for Motor Build ?
One Day
If I want to build a B or D series motors can someone give me the exact tools I will need (measurement and machinist) and the make and model that you use ?
Sort of like a parts list.
Re: Parts list for Motor Build ? (2000Plus)
When building a motor a torque wrench and knowledge is your most important tools by far. Depending what your doing youll need other things.
If your doing a block look into getting:
plastigauge
ring filer
feeler gauge
14mm allen key
dial caliper
For a head some tools will be:
Suction cup tools
lapping compond
14mm allen key
valve spring compressor tool
a straight edge
These are of course tools youll use other then your basic set of tools. But like i said knowledge is the most important tool.
plastigauge
ring filer
feeler gauge
14mm allen key
dial caliper
Suction cup tools
lapping compond
14mm allen key
a straight edge
One Day
Re: Parts list for Motor Build ? (Luserkid)
are any of these needed
1. Dial bore gauge
2. Rod stretch gauge tool
3. Micrometer
4. 3-4" machinist measurement tool
5. 2-3" machinist measurement tool
5. Plastic gauge
6. Torque wrench
7. Feeler gauges
8. Ring filer
9. Tap set
10. Ring compressor
1. Dial bore gauge
3. Micrometer
5. Plastic gauge
6. Torque wrench
7. Feeler gauges
8. Ring filer
9. Tap set
10. Ring compressor
One Day
1. Dial bore gauge
3. Micrometer
5. Plastic gauge (you stated that )
6. Torque wrench (you stated that )
7. Feeler gauges (you stated that )
8. Ring filer (you stated that)
9. Tap set
10. Ring compressor
1. Dial bore gauge
3. Micrometer
9. Tap set
10. Ring compressor
