High flow Convertor or not? - pros? cons? recommendations?
My stock Cat is just about done..... - 167,000 miles 93 Civic SI Hatch - I/H/E - Swap is in the plans for the future. - Waht are your experiences, pros, cons.
And,... Do Integra OEM Cats flow better than Civic - Who knows?
Thanks
Modified by 93CivicSI at 10:57 AM 7/1/2003
Thanks
When I got my carsound put in (at the time, stock manifold and 2-1/2" catback exhaust) I noticed a difference in the low revs, and much throttle response. I also paid around 280 CDN for the whole thing installed, so it wasn't a bad upgrade. And as far as I know, it'll pass emissions. A buddy who's got the same setup (on an sohc vtec) passed emissions no prob.
My Random tech cat gave me 8hp ..So I think it's worth it..No doubt the B16 likes low back pressure and the stock cat was a limiting factor..Have dyno plots if you like to see..
Here's a plot with complete exhaust except the high flow cat...This was the stock cat:
I was really frustrated at this as I only gained 2.5 hp over stock (car was dynoead at 159 hp bone stock)...I tried another cat just for testing to see if the cat was defective,but same result..Then I got my Random Tech high flow cat and went to the dyno again:
up to 168.4 hp..Better..Also put on a Skunk2 catback,but that didn't affect the peak hp (unfortunately..But doesn't matter as the Skunk2 is meant as a preparation for my next project with the car)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmVetteEater »</TD></TR><TR><TD CLASS="quote">Just dont run a cat..... simple as that... saves you money</TD></TR></TABLE>
Uh, no. Don't do that. It's against the law and is shitty for the environment.
take off your cat, get a hammer and a long screwdriver or bar and stick the screwdriver in the hole and
till you can see though it. free high flow cat on the house
then pay the inspector a lil extra and get you that awesome JDM inspection sticker with all the money you saved.
but seriously though, I have a test pipe, no passing inspection, just put on the old cat when you go for inspection, once a year isnt really a pain in the ***.
then pay the inspector a lil extra and get you that awesome JDM inspection sticker with all the money you saved.but seriously though, I have a test pipe, no passing inspection, just put on the old cat when you go for inspection, once a year isnt really a pain in the ***.
I've got a 93 ex with exhaust and a header put on the day or 2 before the cat...
It's a catco direct fit it was under 150 from summit delivered... there was definately a little more throttle response and less backpressure after the cat... overall I like it a lot and would recomend it... Also it seemed to quite the exhaust note a little which I though was odd.. figured it'd be louder but no...
