what fuel pump to get `
my set up so far is a
b18a block ctr pistons
2 layer head gasket
gsr head with a little clean up
stock cams
skunk2 cam guears and manifold b&m fpr.
what fuel pump should i get should i get would a 255 be to much fuel for all motor or should i just get a 190
2 layer head gasket
stock cams
The high pressure 255lph walbro or the regular 255lph. I also need one for my b20vtec w/gsr head(p/p) crv block 84.5mm, 11.5:1 cr?
I'm not sure what the difference is between the two. Is one for turbo applications?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller »</TD></TR><TR><TD CLASS="quote">people have problems turning the psi down with 255lph and b&m fpr. </TD></TR></TABLE>
is this true i was told different i also have the vafc so i could use that to
don't know where you heard that but i'm not having any problems
WALBRO 255LPH GETS A
from me
from me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag R »</TD></TR><TR><TD CLASS="quote">Walbro 255lph</TD></TR></TABLE>
weRd.
weRd.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcx »</TD></TR><TR><TD CLASS="quote">by the way what psi (fuel) are you guys running </TD></TR></TABLE>
I'm wondering the same thing. What psi??
Ruben19
21
Jan 29, 2006 04:12 AM
slowpokecivic
Nov 9, 2005 09:46 PM
