Pass headlight dead fuses and bulb are fine...
Old Jul 1, 2003 | 12:14 AM
SocalCRXsi's Avatar
Default Pass headlight dead fuses and bulb are fine...
Bah I hate eletrical issues....Anyways as the title says my pass headlight low beam is dead had a guy check it out and the fuse location isnt reading power supposedly, So how would i go about fixing this is there anywhere i can run new lines? Or how much you think honda will scam i mean charge me to do it ? Please help so cali cops drool over catching a honda for ANYTHING.
Later,
Sean
Old Jul 1, 2003 | 10:56 AM
EF_LSVtec's Avatar
Default Re: Pass headlight dead fuses and bulb are fine... (SocalCRXsi)
did your headlights used to work before? Can't you just trace the line from the headlight to the switch? It might be time for you to buy a book about your car. Can't be the relay because if it is, then both lights will go out. Might be just a cut wire (lead or ground) somewhere.
Old Jul 1, 2003 | 03:12 PM
team2n1hatch's Avatar
Default Re: Pass headlight dead fuses and bulb are fine... (EF_LSVtec)
if not that, then trace the line and run your own fuse. Maybe the there is a nad connection inside the fuse box, as it is true that there are mulitple fuses for your highs and lows...
Father
Sep 23, 2011 05:54 PM
efcivic317
Mar 16, 2010 02:27 AM
d16trexin
Lighting
Dec 9, 2008 09:11 AM
markstack
Lighting
Oct 7, 2007 06:15 AM
asubennett
Aug 27, 2004 10:13 AM
