B18B into a 89 civic
Old Jun 30, 2003 | 09:35 PM
Ransom's Avatar
Default B18B into a 89 civic
how is this done. i have a 98 b18b block and i am just wanting to know what i have to do to put it in my car. i know as far as the motor goes but the wiring is what i am not sure about. don't really know that much about ob0, ob1, and ob2 stuff. and also will a b16a sir tranny bolt up to the block with out any mods?
Old Jun 30, 2003 | 09:40 PM
spettinger's Avatar
Default Re: B18B into a 89 civic (LudeSH)
please use the search function for far too many posts on this topic. you need:
all OBD 0 sensors from a 90-91 integra. just pull all the sensors and electronics you can from a 90 teg. auto, any trim level, 5 speed, doesn't matter.
a b series cable transmission. can be found in: 90-93 integra, B16 trans (japan only).
motor mounts: hcp, hasport, place racing, az, ghetto homemade, you name it.
shift linkage: ditto. core can be found on a 90 integra.
axles: 90-93 integra. seeing a pattern? strip an integra at the junkyard, you will be glad you did.
jdmb20boi
Jul 1, 2008 07:54 AM
HFpower
Sep 23, 2006 12:00 AM
mannyfresh2.0
Jan 12, 2006 07:05 PM
KeithsDAteg
Jan 24, 2004 05:24 PM
johnlsturbo
Jun 4, 2002 10:43 PM
