smallest crank pulley??
Old Jun 30, 2003 | 08:38 PM
See Are X's Avatar
Default smallest crank pulley??
What is the smallest OEM crank pulley I can get for my 96 LS motor?
reason I ask is my crank pulley sometimes rubs my radius rod in my crx. It's the middle pulley(either AC or PS pulley?) that rubs. So I need a crank pulley that has the smallest diameter for that middle pulley.
Old Jun 30, 2003 | 09:02 PM
IN VTEC's Avatar
Default Re: smallest crank pulley?? (See Are X)
Use a GS-R or ITR. The AC and alternator pulleys are the same size for each pulley with the ITR having the smaller diameter, compared to a non-VTEC B-pulley that has a larger AC pulley over the alternator pulley.
Old Jul 1, 2003 | 04:07 AM
Jeff C's Avatar
https://honda-tech.com/zerothread?id=431952
Old Jul 1, 2003 | 06:36 AM
advanracing62's Avatar
Default Re: smallest crank pulley?? (Jeff C)
what about a N1 pulley? small, light, OEM
Old Jul 1, 2003 | 07:47 AM
See Are X's Avatar
Default Re: smallest crank pulley?? (advanracing62)
i want a pulley with a dampener....if I switched over to a smaller pulley, would I still be able to set the timing right with the marks on the smaller pulley?
acmoc
11
Apr 29, 2009 11:59 AM
tag0617
Apr 12, 2009 06:13 PM
david90
Aug 15, 2003 01:15 PM
fe519
Feb 16, 2003 03:41 PM
