B18A and B18B heads
I know there both PR4 head codes but are there any other differences between them. Can you place a B18A head on a B18B block and keep aprox same compression ratio. Are there any problems with piston to valve clearances. Are the cams the same lift/durations or is one gonna be better then another?
also the manifolds are different from 90/91 and 92+. The later manifolds flow better.
99+ B20Z cams (stamped P75) are also the same as 92+ LS cams, but have a few more degress of duration on the intake cam.
RJ
RJ
hmmm thats strange about the valves b/c went to acuraautomotiveparts.org and they both were listed as the same p/n for 92's and 95 just to throw out some years??? are you sure about the differences in valves??
