what spark plugs are you guys running ?
Old Jun 30, 2003 | 04:10 PM
SPOONfdEK's Avatar
Default what spark plugs are you guys running ?
this is an all motor setup.
Old Jun 30, 2003 | 04:45 PM
blykins's Avatar
Banned
Default Re: what spark plugs are you guys running ? (SPOONfdEK)
OEM NGK Platinum's.
Old Jun 30, 2003 | 04:53 PM
EleanoR's Avatar
Default Re: what spark plugs are you guys running ? (blykins)
NGK copper (replace sooner than NGK platinum OEM)
Old Jun 30, 2003 | 04:56 PM
RTW DC2R's Avatar
Default Re: what spark plugs are you guys running ? (EleanoR)
stock or one heat range cooler. search around there are lots of good plug threads.
Old Jun 30, 2003 | 05:45 PM
len's Avatar
len
I will be running these:
R5671A-7 (stock number 5587)
The reason I'm running these is because I'll have some higher dome pistons installed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">If you are worried about hitting the dome you should go with some retracted tip plugs.</TD></TR></TABLE>
For more information on Spark Plugs vist: http://www.ngk.com/sparkplug411.asp
Old Jun 30, 2003 | 05:49 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EleanoR &raquo;</TD></TR><TR><TD CLASS="quote">NGK copper (replace sooner than NGK platinum OEM)</TD></TR></TABLE>
Same here. Changes every 6-8k miles or so.
Old Jun 30, 2003 | 05:50 PM
Rob Dizzle's Avatar
Default Re: what spark plugs are you guys running ? (ActiveAero)
ef-1 autolite plugs
dyo proven power over ngk blings (platnium)
Old Jun 30, 2003 | 05:58 PM
98itR484's Avatar
Default Re: what spark plugs are you guys running ? (Bob-DC2)
bosch 4227 plugs. $1.99 each, dyno proven on my motor Jeff at IB did a dyno on these also., change them every 10k miles or so. Works great with lots of compression and high lift cams.
Old Jun 30, 2003 | 05:59 PM
Unsung's Avatar
Default Re: what spark plugs are you guys running ? (98itR484)
ngk bkr6e-11
Old Jun 30, 2003 | 06:03 PM
len's Avatar
len
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob-DC2 &raquo;</TD></TR><TR><TD CLASS="quote">ef-1 autolite plugs
dyo proven power over ngk blings (platnium)</TD></TR></TABLE>
Just checked that out a few ago. Rocket is the shizzle. I wonder if he could modify those plugs for me up top.
Old Jun 30, 2003 | 08:48 PM
Nameless RB26's Avatar
Default Re: what spark plugs are you guys running ? (len)
PFR7G-11 NGK platinum
These are the absolute best plugs for an all motor Honda IMO. They come stock on JDM ITR motors. I will use them untill the day I die.
Old Jun 30, 2003 | 09:24 PM
ARACER25's Avatar
What about with boost?
Old Jun 30, 2003 | 09:35 PM
Spoond TEG's Avatar
Default Re: what spark plugs are you guys running ? (ARACER25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ARACER25 &raquo;</TD></TR><TR><TD CLASS="quote">What about with boost?</TD></TR></TABLE>
Denso Iridium Plus Have good Proven Power on FI apps Significant Power gains (FI) but on NA Apps only about 3-4 hp over Stock
Old Jun 30, 2003 | 10:14 PM
ARACER25's Avatar
Default Re: what spark plugs are you guys running ? (Spoond TEG)
Do you have a part number for the Denso Iridium's and a recomended gap?
Old Jul 1, 2003 | 08:25 AM
Spoond TEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ARACER25 &raquo;</TD></TR><TR><TD CLASS="quote">Do you have a part number for the Denso Iridium's and a recomended gap?</TD></TR></TABLE>
IK24 and 0.8mm gap Spoon sells them or you can look at Denso's website for local distributors
Old Jul 1, 2003 | 09:05 AM
sgT's Avatar
sgT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len &raquo;</TD></TR><TR><TD CLASS="quote">The reason I'm running these is because I'll have some higher dome pistons installed.
Sure way to throw away hp.
I cant count the number of pistons I've used but none have come close to
my spark plugs.
Old Jul 1, 2003 | 09:07 AM
HondaGuRu's Avatar
Default Re: what spark plugs are you guys running ? (sgT)
I am running Nology plugs. not bad. expensive too.
Old Jul 1, 2003 | 09:12 AM
sgT's Avatar
sgT
Last I checked, you DONT regap iridium plugs. cant is more likely since they use
the 0.4mm center electrode(which is where the gain is from). Its the same reason
i use the stock NGK platinums is because the 0.6&lt;?&gt;mm center electrode.
You guys think just because copper may be a better conductor that it makes a
better spark, but thats not always the case.
Old Jul 1, 2003 | 09:16 AM
ARACER25's Avatar
Sorry I didn't know.
Old Jul 1, 2003 | 09:40 AM
Tweakmeister's Avatar
dyno proven power over ngk blings (platnium)</TD></TR></TABLE>
I'm trying to get into the dyno to test these.
In the mean time, it's BERU Silverstones.
Old Jul 1, 2003 | 11:26 AM
Hybrid 350GT's Avatar
Default Re: what spark plugs are you guys running ? (Tweakmeister)
I had Denzo Irridiums (SP) until one of them got blown out of the motor. Then while inspecting the damage, another one was on its way out. They were 3 months old. The threads on these things are really soft, apparently. I replaced all of them with NGK plats.
Old Jul 1, 2003 | 11:36 AM
skafia's Avatar
25 Year Member
Default Re: what spark plugs are you guys running ? (DOSPOWND)
OEM NGK.
Old Jul 1, 2003 | 11:55 AM
AllmotorJunkie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blykins &raquo;</TD></TR><TR><TD CLASS="quote">OEM NGK Platinum's.</TD></TR></TABLE>
me too
Old Jul 1, 2003 | 12:02 PM
kungfuSiR's Avatar
NGK Coppers $8CDN A piece
It's fun having an MSD
Old Jul 1, 2003 | 02:32 PM
MiraiZ's Avatar
Default Re: (kungfuSiR)
Apexi #8 I think they are the same as NGK #8's though, but they charge $10 more per plug
