Advancing timing to 18 degrees
Old Jul 27, 2001 | 05:29 AM
jond's Avatar
Default Advancing timing to 18 degrees
I see several people say they've advanced their timing and have gained 5hp or so.
Are there any drawbacks to doing this?
This means the spark fires earlier before TDC right?
Old Jul 27, 2001 | 05:31 AM
BABY NSX's Avatar
Default Re: Advancing timing to 18 degrees (jond)
Run good fuel and you shouldn't have any problems. Keep in mind that 18 degrees is still within spec.
Regards,
Old Jul 27, 2001 | 05:36 AM
D's Avatar
D
- free HP.
and yes, 18 degrees BTDC.
D
Old Jul 27, 2001 | 05:40 AM
jond's Avatar
Default Re: Advancing timing to 18 degrees (D)
I know on my mustang you use a timing light and turn the distributor to change the spark timing. How is it done on the ITR?
Old Jul 27, 2001 | 05:43 AM
BABY NSX's Avatar
Same way!
Old Jul 27, 2001 | 05:50 AM
nerdish's Avatar
Default Re: Advancing timing to 18 degrees (BABY NSX)
Is 18 degrees still in spec for the GSR? Or would you recommend only turning it to 15-16?
Old Jul 27, 2001 | 05:52 AM
Dropspeed's Avatar
Default Re: Advancing timing to 18 degrees (nerdish)
Hondas Spec for the B-series motors is "16 degree + or - 2degree" so yes its within spec
Mattj
Old Jul 27, 2001 | 05:53 AM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Do you have to retard your timing if you're using nitrous?
Old Jul 27, 2001 | 05:55 AM
nerdish's Avatar
Default Re: Advancing timing to 18 degrees (Ross1013)
I think it is highly recommended..
Old Jul 27, 2001 | 06:19 AM
Che Guevara's Avatar
Any warranty issues in doing this? I have to run by the dealer tomorrow, and Im wondering if I should even bother asking them to do this for me.
jond's Avatar
The dealer told my friend that his new prelude will retard the timing if the octane in the gas isn't high enough. Anyone know if the ITR will do that too?
Old Jul 27, 2001 | 06:38 AM
98TypeR's Avatar
also remember to jump the service connector.
when doing this or it will reset itself back to 16
Old Jul 27, 2001 | 06:51 AM
jond's Avatar
Default Re: Advancing timing to 18 degrees (98TypeR)
How do you do that?
Old Jul 27, 2001 | 08:39 AM
FBP_1171's Avatar
It's called a knock sensor. It will only retard if it detects detonation, and yes, all DOHC VTECs have it.
sikek1
Apr 28, 2008 05:49 AM
kixcrx
Nov 10, 2006 10:33 AM
aron0903
Aug 4, 2004 12:34 AM
gsrguy
Feb 7, 2004 02:10 PM
ThisLittleSleepeR
14
Apr 30, 2003 11:16 AM
