Head gasket and compression numbers
Old Jun 30, 2003 | 03:14 PM
Chubz's Avatar
Default Head gasket and compression numbers
My Compression numbers are all even at 270 psi across the board (JDm ITR engine) my question is can I have a blown headgasket and perfect compression. My car needed some coolant thats why i was asking. Engine has never overheated
Old Jun 30, 2003 | 04:03 PM
Warren's Avatar
Wrong-Way Wang
Default Re: Head gasket and compression numbers (B18CR01)
Yes. Leakdown would be a better tool to diagnose a blown headgasket.
Warren
Old Jun 30, 2003 | 05:12 PM
Chubz's Avatar
thanx for the reply
Old Jun 30, 2003 | 05:53 PM
len's Avatar
len
Default Re: Head gasket and compression numbers (Warren)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Warren &raquo;</TD></TR><TR><TD CLASS="quote">Yes. Leakdown would be a better tool to diagnose a blown headgasket.
Warren</TD></TR></TABLE>
Warren, could you explain more about the leakdown. The only leakdown I've ever seen is with the Leakdown test to see if your valves out of spec. ie: bent/stretched.
Thanks,
Len
Old Jun 30, 2003 | 07:12 PM
Warren's Avatar
Wrong-Way Wang
Default Re: Head gasket and compression numbers (len)
Well, if the cylinder is pressurized, and your coolant overflow bottle is bubbling, well, that's bad.
Just listen for the leaking air. It's gotta go somewhere.
Also, look in your valve cover. Is it all milky looking?
Warren
Old Jun 30, 2003 | 08:27 PM
b19coupe's Avatar
You can also buy a fluid head gasket tester at your local auto parts store. You put it on the neck of the radiator, and if the blue fluid turns yellow or green, the head gasket is leaking. It's called a "block tester".
Old Jul 1, 2003 | 02:50 PM
Chubz's Avatar
i pulled the valve cover off and there is no milky residue.
F Bomb
Jan 31, 2008 06:39 PM
smash fascism
Oct 27, 2006 12:38 PM
97itr86
Oct 30, 2004 08:51 AM
hellas
Mar 19, 2004 04:02 PM
Racerage1
Oct 17, 2003 04:15 AM
