High compression and low boost engine setup
Old Jun 30, 2003 | 03:08 PM
simoh's Avatar
Default High compression and low boost engine setup
Hallo guys, I’m new here so please bear with me
I would like to hear your opinion about running a high compression and forced induction at the same time. I could see several advantages, one being that with high compression you get more power throughout the entire revband, both while on and off boosting. With the higher compression you wouldn't need to crank up the boost as much compared to an equal engine running low compression. Thus you could use a smaller turbo and be able to build boost sooner. Disadvantages? Well I think the tuning has to accurate. There is not al lot of error-room with high compression; get the tuning wrong and you will be punished with the detonation of death. Tell me what you think.
Old Jun 30, 2003 | 03:35 PM
Erik B's Avatar
sounds like you were answering a question vs asking.....yes high comp goes good with boost but like you said its all in the tuning.....
Old Jun 30, 2003 | 04:25 PM
DSF's Avatar
DSF
Default Re: High compression and low boost engine setup (simoh)
The Search button is your friend
Luckily today I'm in a good and less sarcastic mood, so I'll be your friend too...
https://honda-tech.com/zerothread?id=516794
https://honda-tech.com/zerothread?id=344690
https://honda-tech.com/zerothread?id=304393
https://honda-tech.com/zerothread?id=243123
...just a taste of the all-mighty search tool
scspeed
Jul 24, 2008 03:53 PM
white2draccord
Apr 28, 2008 03:26 AM
cmasonrun
Oct 6, 2007 11:56 AM
slowcrx954
Nov 23, 2006 07:49 AM
TehMoonRulz
May 16, 2005 01:15 PM
