Which throttle body size would you recommend?
Old Jun 30, 2003 | 02:42 PM
GSlowR's Avatar
Default Which throttle body size would you recommend?
My compression is at 12.6:1 would like to know which throttle body i should use.. i was thinking of boring out the opening to my skunk2 intake manifold to match the new throttle body.. just not sure which size to go with.. I was thinking 70mm but i keep reading that it is too much.. last time i dyno'd i was at 180whp.. that was before port and polish and the high compression skunk2 valves.. I'm guessing I should be around 200whp now..
Old Jun 30, 2003 | 02:56 PM
514_type R's Avatar
Default Re: Which throttle body size would you recommend? (GSlowR)
Id go with a 68mm throtle body, Im aiming at 225whp and its what ill be using(bored ITR throttle body). I also know that erick racing and spoon sell 70mm throtle body
I dont think 70mm will be a problem, its only a question of tuning
Old Jun 30, 2003 | 03:02 PM
GSlowR's Avatar
Default Re: Which throttle body size would you recommend? (514_type R)
main reason i ask.. is cuz i see people even saying 64mm is the max and that 70mm is only good for turbo'd motors.. are you boring out the opening to your intake manifold as well?
Old Jun 30, 2003 | 03:55 PM
quik1's Avatar
I have see dyno charts done on n/a motor with large bore and stock bore t/b and there was no difference at all. The only time it makes a difference is when air is being pushed into the intake ( turbo ).
Old Jun 30, 2003 | 04:04 PM
GSlowR's Avatar
Default Re: Which throttle body size would you recommend? (quik1)
really?? hrmmf.. how modded was the motor tho?
Old Jun 30, 2003 | 09:10 PM
b19coupe's Avatar
My engine-1932 cc motor with Skunk2 Stage 2 cams picked up 2-3 hp throughout the power band with an Erick's Racing 70-68mm tapered TB vs the 62mm Type-R TB. The green line is the big TB.
Old Jun 30, 2003 | 09:27 PM
quik1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSlowR &raquo;</TD></TR><TR><TD CLASS="quote">really?? hrmmf.. how modded was the motor tho?</TD></TR></TABLE>
It was in a book call How To Build Honda Horsepower by Richard Holdener. It has all sorts of different setups that have dyno verified results, its a great book.
Old Jul 1, 2003 | 11:16 AM
Evil DOHC's Avatar
Default Re: Which throttle body size would you recommend? (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">
My engine-1932 cc motor with Skunk2 Stage 2 cams picked up 2-3 hp throughout the power band with an Erick's Racing 70-68mm tapered TB vs the 62mm Type-R TB. The green line is the big TB.</TD></TR></TABLE>
What do you have the vtec set at? Seems like you are loosing lots of hp in the midrange.
EVIL
Old Jul 1, 2003 | 11:56 AM
advanracing62's Avatar
Default Re: Which throttle body size would you recommend? (Evil DOHC)
i'd guess 5.6k
Old Jul 1, 2003 | 12:01 PM
b19coupe's Avatar
Default Re: Which throttle body size would you recommend? (advanracing62)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by advanracing62 &raquo;</TD></TR><TR><TD CLASS="quote">i'd guess 5.6k</TD></TR></TABLE>
At that time, the car was running a chipped P28 ECU, with a 9,200 RPM redline and VTEC at 5600. Good guess.
Old Jul 1, 2003 | 12:54 PM
BERT-O's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik1 &raquo;</TD></TR><TR><TD CLASS="quote">
It was in a book call How To Build Honda Horsepower by Richard Holdener. It has all sorts of different setups that have dyno verified results, its a great book.</TD></TR></TABLE>
That book blows period. (just my .02 cents)
I've seen 2-3 hp on a JG 65mm T/B on a stock GSR block after tuning. 4-8 hp on a modify N/A 1.8L before.
Again, tuning is the key.
Now that I'm thinking, I may take the time and $$$ to compare a stock S2000(62mm, the same as ITR) vs the JG's 65mm in the next upcoming months.
Old Jul 1, 2003 | 02:00 PM
Evil DOHC's Avatar
At that time, the car was running a chipped P28 ECU, with a 9,200 RPM redline and VTEC at 5600. Good guess.</TD></TR></TABLE>
Drop that vtec to 4,700 - 4,900 and you will see HUGE midrange.
EVIL
Old Jul 1, 2003 | 02:06 PM
b19coupe's Avatar
Actually, with the Toda "D"s, if I drop VTEC down that low, the car will run like poop. Toda midrange is very nice, non-VTEC lobes
Old Jul 1, 2003 | 05:25 PM
Evil DOHC's Avatar
I was just talking about the graph you posted, maybe not your current setup. My buddy has an eg making 240 hp at the wheels out of a 1.8 bseries running 12.3 @ 110. His vtec is set at 4,800 with toda spec C's. That car you dont even hear the vtec with ITB's, it just rips.
EVIL
Old Jul 1, 2003 | 06:50 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil DOHC &raquo;</TD></TR><TR><TD CLASS="quote">My buddy has an eg making 240 hp at the wheels
EVIL</TD></TR></TABLE>
Someday...
Old Jul 1, 2003 | 07:01 PM
speedyonez's Avatar
b19coupe sounds like you already have with allmotor 220 to 240+ package how come only 205???
Old Jul 1, 2003 | 07:11 PM
ALLMOTOR18's Avatar
Default Re: (B19c5-eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B19c5-eg6 &raquo;</TD></TR><TR><TD CLASS="quote">b19coupe sounds like you already have with allmotor 220 to 240+ package how come only 205???</TD></TR></TABLE>
His 205 whp was done at Importbuilders...
That is is like 230 whp at Area51....
Old Jul 1, 2003 | 07:19 PM
b19coupe's Avatar
That's what I want to know
I have another block, getting much bigger pistons and going back to the dyno in about a month.
Old Jul 2, 2003 | 08:09 PM
Big Teggie's Avatar
What intake manifold where you using?
Did you port match the tb to the manifold?
Old Jul 2, 2003 | 08:31 PM
b19coupe's Avatar
Default Re: Which throttle body size would you recommend? (Big Teggie)
ITR intake manifold-port matched to the TB.
Old Jul 5, 2003 | 03:26 AM
GSlowR's Avatar
ahh thanks for all the input guys.. I noticed you said 70mm tapered down to 68mm. would 70mm all the way thru be bad? or is it better to get one that tapers down?
hmgemperor2003
Sep 16, 2007 10:16 AM
LU
Nov 10, 2006 10:54 PM
2k1_ITR_0736
Jan 25, 2004 05:06 AM
bryant382
Sep 14, 2003 04:14 AM
B18C2_sedan
Dec 7, 2002 02:40 PM
