Is this Clutch Master cylinder or slave?
Old Jun 30, 2003 | 02:41 PM
BoM's Avatar
BoM
Default Is this Clutch Master cylinder or slave?
the car is a 95 eg hatch
with 95 h22a swap.
it has an act xtrme clutch 4puck, and a new stock flywheel.
on my initial drive it would lose a little pressure. this is after bleeding the clutch.
the clutch has lots of pressure but not like it used to be.
when i was driving it, i would accelerate in second gear up to 5k, then throw it in neutral and apply brakes to slow down, i would then throw it in neutral. this is when i dont' know whats going on.
the clutch pedal stays to the floor for about 2 seconds then i would have to pull it back with my foot (or wait for it to come back) and pressure would still be there.
what could cause that? and what could cause the clutch to have no pressure in the first place. i do not see any leaks. are there test for each part?
Old Jun 30, 2003 | 02:57 PM
Patch's Avatar
Default Re: Is this Clutch Master cylinder or slave? (BoM)
Generally, if you have fluid on the master cylinder pushrod under the dash, its the master. If you see any fluid coming out from around the slave, its the slave. If either one is broken, you should replace them both. Same as replacing both wheel cylinders or calipers. If your fluid level is not going down, and you see no leaks, then you may have an internal master or slave leak. You should still probably replace them both.
Old Jun 30, 2003 | 03:01 PM
EGh22aEG's Avatar
Default Re: Is this Clutch Master cylinder or slave? (CRX PAT)
after a 2 mile drive it will go down, not like the whole cylinder but almost 1/4 does that mean i should replace the slave and master cylinder......if so approximatly how much would that cost at a shop with parts i work alot now and dont have the time to mess around with it
Old Jun 30, 2003 | 03:21 PM
Patch's Avatar
Default Re: Is this Clutch Master cylinder or slave? (EGh22aEG)
Yeah, if you're losing fluid, one of them is leaking. Its really not that hard to do yourself. The parts would probably cost you $60-100 for the slave and master. Do yourself a favor and don't get Autozone or the normal parts house crap, or you'll be changing it again in a year. If you went to a shop, I'm sure they would charge you $200-$400. You should definately try to tackle it with a buddy on Sunday.
Old Jun 30, 2003 | 04:28 PM
BoM's Avatar
BoM
mike, go buy both parts and i'll install em.
Old Jul 3, 2003 | 01:55 PM
EGh22aEG's Avatar
i bought the parts from honda today make sure you dont forget to come on sunday so i can order my suspension and ill let you run it at atco haha thanks
Old Jul 3, 2003 | 03:11 PM
~~~InNeEdFoRsPeEd~~~'s Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGh22aEG &raquo;</TD></TR><TR><TD CLASS="quote">i bought the parts from honda today make sure you dont forget to come on sunday so i can order my suspension and ill let you run it at atco haha thanks</TD></TR></TABLE>
do you happen to have the parts number and how much did it cost?, i need to replace those parts also it's leaking fluid right where the clutch pedel is under the dash
Old Jul 3, 2003 | 03:25 PM
JDMHEIM's Avatar
I HAVE A 94 CIVIC CX WITH A JDM B18C AND I HAD THE SAME PROBELM. I REPLACED THE SLAVE AND THE MASTER AND IT MADE WORLD OF DIFFERENCE. I WORK AT A HONDA DEALER AND WE ALWAYS REPLACE THEM AS A PAIR.
BEST OF LUCK
JDMHEIM
YEAH I PAID FOR BOTH AROUND 165 BRAND NEW AND DON'T GO AFTERMARKET IT IS ALL **** GO HONDA
Old Jul 3, 2003 | 04:20 PM
poison's Avatar
This sounds like it's the clutch master cylinder with air going into the system.
I would completely bleed the system and put DOT 3 brake fluid in it, making sure there is all clean brake fluid in there, and see how it does.
If all else fails, I would definitely recommend replacing it.
Old Jul 5, 2003 | 09:16 AM
EGh22aEG's Avatar
Default Re: Is this Clutch Master cylinder or slave? (~~~InNeEdFoRsPeEd~~~)
the part number for the h22a slave cylinder is 46930-SM4-003 and the master cylinder for a 95 cx hatch is 46920-SR3-A01
Old Jul 5, 2003 | 12:57 PM
spooned out's Avatar
you can get the master cylinder at NAPA for about $72 bucks (limited lifetime warranty) and its also made in Japan ..... good luck
EddieLe76
Jan 14, 2010 01:50 PM
Surestick
Aug 23, 2006 10:56 AM
ViZ
Sep 18, 2003 12:19 PM
92CIVICCX
Sep 26, 2002 05:16 AM
Integra_Boi
Nov 18, 2001 03:05 PM
