legend/nsx calipers
Old Jun 30, 2003 | 01:01 PM
NA gs-R 05 C
Guest
Posts: n/a
Default legend/nsx calipers
i searched but no results, does any 1 know if legend calipers would fit behind stock gsr wheels ?
Old Jun 30, 2003 | 01:28 PM
Mr.Integra's Avatar
Default Re: legend/nsx calipers (NA gs-R 05 C)
it woudln't fit
like the itr calipers, it requires shaving in order to make it fit. install is the same for itr and legend calipers.
legend calipers are designed for 28mm rotors, unlike the tiny ones that come with our integras. So it is reccomended to get the 28mm legend rotors redrilled to make it for our cars.
Old Jun 30, 2003 | 02:03 PM
NA gs-R 05 C
Guest
Posts: n/a
Default Re: legend/nsx calipers (Mr.Integra)
thanks for the quick response.
Old Jun 30, 2003 | 05:14 PM
Sportmode's Avatar
is it the same with NSX calipers?
Old Jun 30, 2003 | 06:49 PM
romeo619romeo's Avatar
Default Re: (Sportmode)
i heard also you need to switch the right and left side when you put it in the integ
Old Jun 30, 2003 | 07:05 PM
P1mpSlap's Avatar
I believe if you call Brian over at http://www.fastbrakes.com he can sell you just the caliper adapters to mount the Legend or NSX calipers without any machining.
I think this is the kit:
http://www.fastbrakes.com/prod...liper
Old Jun 30, 2003 | 07:37 PM
Mr.Integra's Avatar
Default Re: (romeo619romeo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by romeo619romeo &raquo;</TD></TR><TR><TD CLASS="quote">i heard also you need to switch the right and left side when you put it in the integ</TD></TR></TABLE>
you heard wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.fastbrakes.com/prod...liper</TD></TR></TABLE>
that site says nothing about adaptars to mount legend or nsx calipers w/out any machine work. It only says that the itr calipers are modified to allow exact fitment over stock rotors.
Old Jun 30, 2003 | 08:06 PM
P1mpSlap's Avatar
Default Re: (Mr.Integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Integra &raquo;</TD></TR><TR><TD CLASS="quote">
Regardless, you'll need this bracket. The NSX / Legend will not function or fit correctly on the 10.2" rotor without caliper relocation. You'll need this bracket to do this.
Old Jun 30, 2003 | 08:49 PM
4potnick's Avatar
Default Re: (P1mpSlap)
Do you know how much the adapters run?
Old Jun 30, 2003 | 08:51 PM
P1mpSlap's Avatar
i'm not really sure
email brian over at fastbrakes.com, he's pretty quick about answering emails.
Old Jun 30, 2003 | 11:32 PM
Mr.Integra's Avatar
Regardless, you'll need this bracket. The NSX / Legend will not function or fit correctly on the 10.2" rotor without caliper relocation. You'll need this bracket to do this.</TD></TR></TABLE>
woudl you need the bracket with ITR rotors?
hmongboyLS
Jan 1, 2004 08:00 PM
morepoop4u
Sep 20, 2002 03:40 PM
B18C-EJ1
Dec 17, 2001 01:59 PM
fso_BamBam
Sep 15, 2001 03:43 PM
